Hi Micah,
Yes they are multipatch, and you are correct that there has been a limitation in publishing multipatch to ArcGIS without Portal. Fortunately, with the Pro 1.3 release happening this month, will enable you to publish your multipatch as a "scene package", which can be used directly in ArcGIS Online, with no Portal needed.
Cheers,
Dan
Hello Daniel. Do you have any instructions on publishing a scene package. Installed the new 1.3 update today and dont see anything related to scene package.
Thanks in advance
Hi Ryan,
You would use "create scene package layer followed by 'share package'
Cheers Gert
Thanks for the help guys!
Gert,
I try to apply the tasks from your Local Government Schematic Scene solution to my project. All worked fine for sample data, but for the data I use there is a following error while trying to run Extract Roof Form tool. Would you be able to help me fix this problem?
Thank you,
Emilia
Same exact error here. Have no idea whats happening.
Hi Emilia,
This error is possibly due to incorrect values for minimum flat or slope roof areas. Keep in mind that the default values are in square feet. If your base data is in meters, you will need to convert these values to square meters.
Otherwise if you can send me some sample data, I am happy to see what is going on.
Gert
Hi Emilia,
It looks like Ryan Key ran into the same issue and posted below his solution. Do you have the same duplicate ObjectID field issue?
Dan
Has anyone figured this out? Im gettimg the same error as well.
In my case Derek my building footprint data had an ObjectID field and an additional field ObjectID_1 which was generating the error. I deleted the second Object ID field and it worked like a charm. Hope that helps
