cityengine is crashing! HELP!
6530
22
12-31-2011 06:29 AM
MichaelJones9
Hi guys,
I just installed CityEngine trial. The problem is that when I open CityEngine, it opens for 1-3 seconds and then closes. Then a dialog window appears saying:"An error has occurred, please see the log file."
Now I didn't know exactly what to see in the log file because there are too many words in it. So I attached the log file.
Hope someone can solve my problem 🙂
Thanks.
MatthiasBuehler1
hi Michael,
can you post also the system specs like OS, amount of RAM, graphics card model ?
first thing I'd try is update the graphics driver.
let me know ..
kind greetings !
MichaelJones9
hi Michael,
let me know ..
kind greetings !
Hey Matthias, these are my system specs:
I have Windows XP, service pack 3
My Processor is Intel Core 2 Duo CPU
E7300 @ 2.66GHz, 2.67GHz.
My PC has 2.99 GB of RAM
I have Directx 9,
and my Video Card is: Nvidia GeForce 210 and I bought it like a month ago, I don't think it needs to be updated.
Thanks.
MatthiasBuehler1
hi !
can you do a general search on C: and try to locate an error loc named "hs_err" ? if one was created, it is named somewhat like this.
additionally, you could try to delete the folder called ".CityEngine". this is a hidden folder located in your user account.
can you try this ?
please let me know.
MichaelJones9
matthiasbuehler,
I searched for the "hs_err" file and it was only found in Firefox folder and not in CityEngine folders.
I also deleted the ".CityEngine" folder but it is still crashing when I open it.
MatthiasBuehler1
hi !
sorry for your inconvenience!
a hs_err file may get created and it may also be created in different locations, not necessarily in the CE folders.
[do not ask me why, that's what I was told. :)]
what you can do it compare the creation time of the hs_err file.
if you find one (anywhere on the harddrive) which was created in the same minute the CE crashed last, it's very likely this file may help us.
I am not sure anymore, did you try and completely remove the installation, delete the CE program folder and run the TRIAL installer again ?
Please let me know ..
m.
Leandro-Zamudio
I have the same problem and i have a hs_err file in the attachement. Apparently i have a problem with a fatal error in Java Runtime Environment.
I appreciate your help
Thank you
MatthiasBuehler1
Hi !
I cannot access that file .. strange.
Can you post the file again, maybe as zip or just in a plain text quote ?
Jose_CarlosCosta
The same is happening to me.
I Have tried the given solutions, but did not work.
Regards
MatthiasBuehler1
Hi Jose ..
Can you post the precise steps you do until CE crashes ? Please add screenshots.
Also, try to find the 'hs_err.log' which CE creates after the crash. Search your drive for 'hs_err'. The file can be placed in different locations. Can also be that no file is created.
Let me know ..
Matt
