CityEngine- being able to choose texture for facades
5165
6
06-03-2015 01:34 AM
Rosa_
New Contributor II
I'm creating a real city in CE and I'm using a shape file for buildings. I must use different textures for each facade, so I should create a rule that allows me to choose the texture for each facade. Anyone can help me? Thanks.
MicahTaylor
Occasional Contributor III
Ok...I think I understand. You want to select facades for different faces of a single model (such as walls).
You would need to separate the walls in the code into individual components...and then write a rule for each one....for example....
attr HEIGHT = 10
attr texturesFront = fileRandom("assets/Brick_Red_Wall.jpg")
attr texturesRight = fileRandom("assets/Brick_Red_Wall.jpg")
attr texturesLeft = fileRandom("assets/Brick_Red_Wall.jpg")
attr texturesBack = fileRandom("assets/Brick_Red_Wall.jpg")
@StartRule
Lot -->
    extrude(HEIGHT)Bldg
Bldg --> comp(f){front : FacadeFront | right : FacadeRight | left : FacadeLeft | back : FacadeBack | top : Roof }
FacadeFront -->
     setupProjection(0, scope.xy,'1,'1)
     texture(texturesFront)
     projectUV(0)
FacadeRight -->
     texture(texturesRight)
     projectUV(0)
FacadeLeft -->
     texture(texturesLeft)
     projectUV(0)
FacadeBack -->
     texture(texturesBack)
     projectUV(0)
Roof -->
    roofGable(45,0,0,false,0)
However, this may be a bad way to do it if you do not have exactly 4 walls. I would suggest clicking on your "Help" option and search for the "Comp Split Operation".  It will give you an idea of how the rule file identifies a single face.
But again, there are lots of rules online (mostly inside of tutorial downloads) that work great and can be modified to do what you need.
MicahTaylor
Here is a link to tutorials that have a lot of building rules with the download; you can modify these to use your textures.
CityEngine Gallery | ArcGIS Resource Center
You can use the file path of the textures in those rules (usually in "assets/textureName.jpg") and just add your own textures into the assets folder....("assets/YOURtextureName.jpg").
A simple way to select your own texture in the inspector window (with a browse button) is to make an attribute for your texture in the rule file.
for example....
attr HEIGHT = 10
attr Mytextures = fileRandom("assets/Brick_Red_Wall.jpg") #THIS MAKES TEXTURE SELECTABLE!!
@StartRule
Lot -->
    extrude(HEIGHT)MakeBuilding
MakeBuilding --> comp(f){side : Facade | top : Roof }
Facade -->
     texture(Mytextures)
     projectUV(0)
Roof -->
This will allow you to select a building in the scene...and choose its texture from the inspector window.
Good luck!
Rosa_
New Contributor II
Thanks for your timely response. Does this rule allow to select a different texture for each facade of building?
If building has four facades, I should select four different texture.
MicahTaylor
attr HEIGHT = 10
@StartRule
Lot -->
    extrude(HEIGHT)Bldg
FacadeFront -->
     projectUV(0)
FacadeRight -->
     projectUV(0)
FacadeLeft -->
     projectUV(0)
FacadeBack -->
     projectUV(0)
Roof -->
MicahTaylor
Also, be sure your facade pictures (jpg, png, etc..) are saved in your assets folder.
Rosa_
New Contributor II
Thank you very much, you have solved my problem. This rule is perfect!!!
BenjaminChmiel
I had the same problem. Would you be willing to share this rule with me?
