Can anyone offer me any help with why I am getting a "Mismatch Token" error in this rule on the line indicated in bold?
1298
01-03-2017 12:26 PM
LindaBarrett2
@Range ("Gable","Hip","Flat","Pyramid")
attr RoofType = "Gable"
@Range ("Bungalow","SplitLevel","TwoStorey","ThreeStorey")
attr myUseType = "Bungalow"
@StartRule
BronteFootprints -->
comp (f) {top:Roof |side:Wall}
Extrude -->
         extrude(myUseType)
* case whatUse == "Bungalow" : BungalowUseType
   case whatUse == "TwoStorey" : TwoStoreyUseType
   case whatUse == "ThreeStorey" : ThreeStoreyUseType
   case whatUse == "SplitLevel" : SplitLevelUseType
   else: Other.
BungalowUseType -->
            BungalowUse (2.75)
TwoStoreyUseType -->
T         woStoreyUse (5.5)
ThreeStoreyUseType -->
         ThreeStoreyUse (8.25)
SplitLevelUseType -->
         SplitLevelUse (4.15)
Roof-->
         case RoofType == "Gable" : GableRoof
         case RoofType == "Hip" : HipRoof
         case RoofType == "Pyramid" : PyramidRoof
         else: FlatRoof.
         color (0,1,0)
GableRoof-->
roofGable(30)
HipRoof-->
roofHip(30)
PyramidRoof-->
roofPyramid(30)
Wall-->
color (46,46,46)
ThomasFuchs
Hello Linda,
Thank you for your question. The CGA language is structured by concatenating rules. Separating parts of a rule that are common from conditional ones helps in analyzing the shape tree. So if you are using a case statement, it has to be encapsulated in a conditional rule.
Everything preceding the conditions needs to be put into a separate rule. It is possible to generate different successors for different conditions of rule parameters or shape attributes. The case and the else statements must build a consecutive block and can not be interrupted with successors (like a switch-case block, NOT like if statements in well-known programming languages).
PredecessorShape -->
                     case condition1: Successor1
                     case condition2: Successor2
                     else: SuccessorN
DuliniRatnayake
Hi Linda,
You need a conditional statement as Thomas mentioned but I would use attribute data to extrude buildings foot prints, which is less complex.I am also working on a similar rule.
Call me if you need any help.
Dulini
LindaBarrett2
Hi Dulini,
I may do that.  Thanks for your help
LR
You're trying to extrude using text as parameter. You're also never calling the Extrude rule. Case rules also can't have any commands but cases. Try this instead:
@Hidden
attr myUseTypeHeight = 0
@StartRule
Lot -->
 SetHeight
SetHeight -->
 case myUseType == "Bungalow": set(myUseTypeHeight, 2.75) Extrude
 case myUseType == "SplitLevel": set(myUseTypeHeight, 4.15) Extrude
 case myUseType == "TwoStorey": set(myUseTypeHeight, 5.5) Extrude
 case myUseType == "ThreeStorey": set(myUseTypeHeight, 8.25) Extrude
 else: set(myUseTypeHeight, 1) Extrude
Extrude -->
 extrude(myUseTypeHeight)
 comp (f) {top:Roof |side:Wall}‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
LindaBarrett2
Thank you - this is exactly what I was looking for.
