"Hole" in cityengine
6637
32
03-24-2014 03:50 AM
AnaGalego
I have with troubles to enter private buildings thoroughfares.
the cityengine not assume that those playgrounds are empty. anyone have a solution?
BenLeslie1
Similarly the offset rule also fills holes in 2014.1 if a negative offset value is used.
Is there a way to procedurally remove this unwanted hole-offset-geometry?  comp(f) doesn't seem to have necessary options.
MatthiasBuehler
did you try the 'border' and 'inside' selectors ?
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
matthias.buehler@garsdaledesign.co.uk
www.garsdaledesign.co.uk
BenLeslie1
Yep - trouble is a border and an inside is created for both the hole and the proper shape, so the following code produces the following image:
offset(-2)
comp(f){border:NIL|inside:Cyan}
