In Notepad++ there's a neat bit of functionality whereby, when you select a term, all instances of it thoughout your text are automatically highlighted in green. This is really handy because it allows you to easily see where instances of the same term are in relation to each other (the find tool in CE doesn't do this because it only highlights one item at a time).
It would be great if this were implemented in the cga editor.
right click on a attribute or rule name -> find References has been implemented recently.
