Territory Design wizard returns 0 territories
1128
03-14-2018 02:53 PM
deleted-user-P-Gckloxqib2
Any idea why the parameters below return a blank table with no territories from the territory design wizard?
Thanks in advance for your help!
Territory layer name: March_14_2018_3
Creation time: 2018/03/14, 17:16:42
Last modification time: 2018/03/14, 17:44:58
Last modified with: Territory Design Build# 10.6.0.920
Comments:
Territory layer datasource path: c:\my output data\projects\usa\territories\march_14_2018_3
Alignment Layer:
Alignment Layer name: March_14_2018_3.ZIP Codes
Alignment Layer dataset path: C:\ArcGIS\Business Analyst\US_2017\Data\Demographic Data\ZIPCodes_zp_esri.bds
Network dataset: C:\ArcGIS\Business Analyst\US_2017\Data\Streets Data\NorthAmerica.gdb\Routing\Routing_ND
Barrier layers:
C:\McAllister\Data\Simplified_Layers.gdb\Franchise_PDR_50
C:\McAllister\Data\Simplified_Layers.gdb\FRanchise_PDES_50
Territory Design Extent defined: Yes
Set Extent to: Business Analyst Study Area
Study Area name: USA
Territory Design Extent calculation method: Polygon centroid contained within extent
Number of territory levels in hierarchy: 1
Level name: Territories
Number of territories in level: 0
Territories creation type: With Summary Data
Manual correction: No
Territory creating options:
Territories naming: Assign default territory names
Initial territories number: 0
Number of territories to be created: Optimal
Use capacity value(s) for territories: Yes
Capacity variable(s):
2017 Total Population:
Minimum: 500000.00
Maximum: 800000.00
Preference: 100%
Fill extent automatically: Yes
Override constraint parameters: Yes
Clustering options:
Territory locations will be calculated using: Spatial locations only
Density influence for locating territories: 50%
Balance territories: No
Distance type: Network Analyst (time): c:\arcgis\business analyst\us_2017\data\streets data\northamerica.gdb\routing\routing_nd - TravelTime
Distance units: Minutes
Maximum distance that a territory is away from its seed point or center: 120
Minimum distance from territory center: Not specified
Minimum distance between a territory centers: Not specified
Compactness: 75%
Territory center allocation method: Center of density
Territory centers will be calculated using: Spatial locations only
Territories were automatically balanced: No
Current level parameters:
Minimum: 500000.00
Maximum: 800000.00
Preference: 100%
Tags (1)
JohnPreysner
THowser-esristaff‌, kwatson-esristaff‌, or PSrivastava-esristaff‌ - is this something one of you would be able to assist with?
KyleWatson
Hello again Sunnie.  We could probably understand what is happening here if we had your source data to test with.  For now, can you successfully build territories using a straight-line distance calculation rather than the network distance?  The issue could be in the network data, or it could be that + the Population criteria you've entered cannot be met.  So you could also try to modify the population constraints to see of allowing a larger number will return successful results.  This is of course without us having the data.  If you sent the data to Support we can try to reproduce and offer more definitive suggestions.
Kyle
Kyle,
Can we set a time to discuss the data you need from me?
I have not had success building territories with the network dataset, which is extremely important to us and overriding constraints were set in the design.
I’ve chopped up the area and made TNI’s but I’m still getting some failing issues and I need to get all territory solutions together for my report.
Kyle,
