I have support case#02781660
C:\Temp\geoenrichment_data_management show:
2021-04-09 17:11:52.759 Traceback (most recent call last):
2021-04-09 17:11:52.759 File "C:\Program Files\ArcGIS\Server\tools\GeoEnrichment\DatapackManagement\manageData.py", line 833, in deleteData
2021-04-09 17:11:52.762 failed2Delete = deleteSpatioTemporalData(dataStoreInfo, metadataContext, datapackInformation)
2021-04-09 17:11:52.762 File "C:\Program Files\ArcGIS\Server\tools\GeoEnrichment\DatapackManagement\deleteSpatioTemporalData.py", line 70, in deleteSpatioTemporalData
2021-04-09 17:11:52.763 failures = deleteStdGeographies(elasticSearchClient, STD_GEO_ALIAS, datapackInformation)
2021-04-09 17:11:52.763 File "C:\Program Files\ArcGIS\Server\tools\GeoEnrichment\ElasticsearchUpload\elasticSearchUploadStdGeographies.py", line 881, in deleteStdGeographies
2021-04-09 17:11:52.765 result = elasticSearchClient.delete_by_query(','.join(indexAliases), body, params={'refresh': 'true'})
2021-04-09 17:11:52.765 File "C:\Python27\ArcGISx6410.8\lib\site-packages\elasticsearch\client\utils.py", line 84, in _wrapped
2021-04-09 17:11:52.766 return func(*args, params=params, **kwargs)
2021-04-09 17:11:52.766 File "C:\Python27\ArcGISx6410.8\lib\site-packages\elasticsearch\client\__init__.py", line 1113, in delete_by_query
2021-04-09 17:11:52.769 "POST", _make_path(index, "_delete_by_query"), params=params, body=body
2021-04-09 17:11:52.769 File "C:\Python27\ArcGISx6410.8\lib\site-packages\elasticsearch\transport.py", line 350, in perform_request
2021-04-09 17:11:52.771 timeout=timeout,
2021-04-09 17:11:52.771 File "C:\Python27\ArcGISx6410.8\lib\site-packages\elasticsearch\connection\http_urllib3.py", line 257, in perform_request
2021-04-09 17:11:52.773 self._raise_error(response.status, raw_data)
2021-04-09 17:11:52.773 File "C:\Python27\ArcGISx6410.8\lib\site-packages\elasticsearch\connection\base.py", line 182, in _raise_error
2021-04-09 17:11:52.774 status_code, error_message, additional_info
c:\temp\geoenrichment_environment_configuration logs show:
2021-04-10 12:51:25.777 Traceback (most recent call last):
2021-04-10 12:51:25.777 File "C:\Program Files\ArcGIS\Server\tools\GeoEnrichment\EnvironmentManagement\manageEnvironment.py", line 415, in createEnvironment
2021-04-10 12:51:25.778 if not context.server.isBusinessAnalystLicensed():
2021-04-10 12:51:25.778 File "C:\Program Files\ArcGIS\Server\tools\GeoEnrichment\Utilities\portalUtil.py", line 379, in isBusinessAnalystLicensed
2021-04-10 12:51:25.779 return ('isValid' not in extension.keys() or extension['isValid'] == True) and (long(extension['expiration']) >= time.time() * 1000.0)
2021-04-10 12:51:25.779 KeyError: 'expiration'
2021-04-10 12:51:25.779 'expiration'
2021-04-10 12:51:25.779 LOG [FATAL]: Internal error.
same machine's licenses:
For those interested this issue was logged as a defect in BUG-000134990.
Regards,
Jason R.
Regards,
Jason R.
