Esri Business Analyst 10.5.1 Address Coder Toolbox not licensed
2091
12
01-05-2018 12:37 PM
Jeffcheng1
I have problem to use Address coder in BA 10.5.1. And I have BA license and authorized in ArcGIS.
It pop up error like:
"Failed to execute. Parameters are not valid.
ERROR 000824: The tool is not licensed.
Failed to execute (SetupCustomersByTable)."
I test the Arcpy in ArcMap 10.5.1. It shows "Notlicensed" if I enter "arcpy.CheckOutExtension("Business")", but BA works totally fine if I enter "rcpy.CheckOutExtension("BusinessPrem") and allother module works fine under BusinessAnalyst Toolbox.
On the extensions panel, I have two Business Analyst option, but only able to check one, another one is Not authorized.
Does anybody know the reason why BA is not working? Thanks in advance.
PavanYadav
Hi Levi,
I am not sure if JC_UMASSMED have had a chance to work with Support Services. But, if you're available can you please contact us at 888-377-4575 X 2 to have a case created?
Thank you.
Pavan Yadav
Technology Lead, Esri
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
Levi_Bonnell
I ended up downloading arcgis 10.6.1 and 2018 BA. Everything worked.
PavanYadav
Thank you for the update. I am glad you have been able to resolve the issue.
Regards,
Pavan Yadav
Pavan Yadav
AI for Imagery
