Hi GeoNet
I would like the possibility to make a drive/walk time analysis on a parcels layer (polygon), and make an infographic/report based on that area. Right now you have to set a point to make the area, which is counter intuitive when you already have a parcels layer that the customers use to check store area and such.
/Niklas
Hello Niklas,
Thank you for adding this idea. There are tools in ArcGIS Online to generate centroids from a polygon layer and then use those to create drive/walk time around the centroid.
Could you provide more information on your use case for this idea?
Thank you,
Praveen Srivastava
ArcGIS Business Analyst Team
