ArcGIS Business Analyst Ideas
Latest Activity (88 Idea Submissions)
Sort/Filter :
Open
It would be really helpful to add state legislative districts (upper and lower) as standard geographies in Business A...
ArielLow2146
by ArielLow2146 Occasional Contributor II
in ArcGIS Business Analyst Ideas Last Updated 03-11-2024
0 1
Open
It would be best to have an option to increase the maximum limit over the current value of 5,000 points when using Ar...
kntr
by kntr New Contributor III
in ArcGIS Business Analyst Ideas Last Updated 02-23-2024
1 1
Open
Currently if you've added a chart or an infographic there is no way to add other elements to the chart or infographic...
ArielLow2146
in ArcGIS Business Analyst Ideas Last Updated 11-21-2023
1 0
Open
There used to be a 'number of households that own a pet' data point, but now there is just owns 1 dog, owns 1 cat etc...
KevinO_Brien
by KevinO_Brien New Contributor II
in ArcGIS Business Analyst Ideas Last Updated 11-10-2023
0 1
Under Consideration
I am building a custom infographic and have set up a number of charts to use compare with geographies. I would like t...
ArielLow2146
in ArcGIS Business Analyst Ideas Last Updated 04-13-2023
1 2
Implemented
We are using the infographics tool in Business Analyst to make custom infographics for each county in our state. (Cur...
AmyRoust
by AmyRoust Occasional Contributor III
in ArcGIS Business Analyst Ideas Last Updated 10-26-2022
1 4
Open
Several students in a class I teach about using Business Analyst Online have suggested a clearly outlined or labelled...
Dr_Mighty
by Dr_Mighty New Contributor II
in ArcGIS Business Analyst Ideas Last Updated 06-27-2022
2 0
Open
The new comparison panel is awesome - thank you! I think conditional text (value)/images (arrow?) would be a great ad...
ColinMcNamara
by ColinMcNamara New Contributor III
in ArcGIS Business Analyst Ideas Last Updated 03-30-2022
1 2
Open
Some of the reports that rely on InfoUSA's data can be fairly inaccurate, but the ability to modify the inputs for th...
JonathanBarnett1
by JonathanBarnett1 New Contributor II
in ArcGIS Business Analyst Ideas Last Updated 03-23-2022
1 0
Under Consideration
When conducting a Business search within Business Analyst online, it would be really useful to have the actual indust...
Brian_Colson
by Brian_Colson New Contributor III
in ArcGIS Business Analyst Ideas Last Updated 12-01-2021
2 2
Closed
Hi there, it would be very useful to access BAO using arcgis api for Python.Would you happen to know if something lik...
Roxana_ElenaUrdea
by Roxana_ElenaUrdea New Contributor III
in ArcGIS Business Analyst Ideas Last Updated 05-02-2022
0 2
Under Consideration
As suggested by ESRI technical support I want to bring to your attention this useful but missing capability:Have the ...
Roxana_ElenaUrdea
in ArcGIS Business Analyst Ideas Last Updated 10-14-2021
3 1
Open
It appears that the selection of analysis areas for drive and/or walk times in Business Analyst are only available fo...
KeithHenderson
by KeithHenderson New Contributor II
in ArcGIS Business Analyst Ideas Last Updated 07-19-2021
1 0
Implemented
Business Search using Data Axle includes the Industry Description in the results.When exporting/saving the results as...
JonathanLee
by JonathanLee New Contributor III
in ArcGIS Business Analyst Ideas Last Updated 02-10-2022
0 3
Under Consideration
I need to get the business points for large employers in my area.  However, if you recall, the flow for BAO starts ou...
JayLarsen
by JayLarsen Occasional Contributor II
in ArcGIS Business Analyst Ideas Last Updated 05-07-2021
1 1
95 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
