Helicopter VFR Runway Obstruction Clearance
1395
10-05-2022 12:01 PM
TroyMeuth
I am using 2.9 and trying to overlay the obstruction surfaces/zones over and around the runway per UFC 3-260-1 figure 4-1 to create a 3d view but can not figure out the correct tool to use in the toolbox. Looks like it only allows for helipads. I do have a 2d kmz file overlay that I imported but when trying to add z data it moves the lines. I am new to this so it may just be user error.
DavidWickliffe
Hi Troy,
 The Unified Facilities Criteria (Aviation) tool within the Airports toolset\>Obstruction Identification Surfaces toolset may be used.  The input is polylines for a runway and there is a wing type = rotary that can be used for helicopter VFR runway.
see:  https://pro.arcgis.com/en/pro-app/latest/tool-reference/aviation/ufc.htm
DavidWickliffe
Hi Troy,
TroyMeuth
Perfect! Thank you.
