Zoomin/zoomout/location buttons in qml
2047
6
08-11-2016 11:57 AM
DavidStajan
New Contributor III
I'm using app studio and I would like to add the buttons to the map for GPS/zoomin/zoom out (see attachment). The screen shot was taken from an app built using the mapveiwer template. I've been scanning the code for that template but I don't see any particular lines that would be inserting these buttons. Is this built into the map api? Anyone have any idea?
David
by Anonymous User
Not applicable
Hi David
Do a global search in the project for the text "ZoomButtons" and you should find the object. I believe it is a custom object created by the AppStudio team, so you can go into it and customize it a little, e.g. change icons etc.
If you want to use the object in your own app, make sure you have this import statement:
import ArcGIS.AppFramework.Runtime.Controls 1.0
then just add the object and go from there...
Cheers,
-Paul
DavidStajan
New Contributor III
Thanks Paul.  I came across someone else talking about ZoomButtons in another thread but when I search for the object in the code it comes up with no matches.  Have you used this object before?
by Anonymous User
Not applicable
Look in WebMap.qml, around line 285.
DavidStajan
New Contributor III
I don't have such a file in the project.  There's a webmap.js file but no webmap.qml. Are we talking about the same code base?  I'm referring to this mapviewer https://www.arcgis.com/home/item.html?id=0faea839dea644e688da36bccae87aa8
MarikaVertzonis
The zoom buttons are a component in AppFramework.Runtime.Controls.
The simplest example of this component in use, is the Hello World (Runtime) starter template. In this example the qml used to define the buttons is this:
        ZoomButtons {
            anchors {
                right: parent.right
                verticalCenter: parent.verticalCenter
                margins: 10
DavidStajan
New Contributor III
Thanks Marika.  I finally found it.
