Update Features
5144
18
05-07-2019 01:26 PM
jaykapalczynski
Honored Contributor
I am referencing the Update feature template in AppStudio.....
I am trying to add another Combobox AND Text field that will be populated with the appropriate values once the feature is selected.  If I add the variable below "varhabitable" The popup never occurs to allow me to click into the update popup.
If I comment this line
varhabitable = selectedFeature.attributes.attributeValue("habitable");
I can run the app but the combobox is not populated with the value of that record.
How do I build the update box with multiple Fields for update including text fields?
// signal handler for selecting features
onSelectFeaturesStatusChanged: {
   if (selectFeaturesStatus === Enums.TaskStatusCompleted) {
      if (!selectFeaturesResult.iterator.hasNext)
          return;
         selectedFeature = selectFeaturesResult.iterator.next();
         vardamageType = selectedFeature.attributes.attributeValue("typdamage");
         // show the callout
        callout.x = mousePointX;
        callout.y = mousePointY;
        callout.visible = true;
     // set the combo box's default value
       damageComboBox.currentIndex = featAttributes.indexOf(vardamageType);
       damageComboBox2.currentIndex = featAttributes.indexOf(varhabitable);
jaykapalczynski
Honored Contributor
I ran the app in QT Creator with this:
To run your app in Qt Creator, click Run on the Tools > External > AppStudio menu. (You can also press Alt+Shift+R on your keyboard.)
I see this error:
ArcGIS.AppFramework.Player: Object: QObject(0x0) Text: "file:///C:/Users/tjv36463/ArcGIS/AppStudio/Apps/25ab7e6bad9b43508700122d31c63f43/Samples/UpdateFeatures.qml:124: Error: Cannot assign [undefined] to QString"
The funny thing is I am positive there are values in the data for the fields ... very puzzled...will try and reach out to ESRI for solution
ErwinSoekianto
Esri Alum
Jay,
Yes, at this point, it is best to work with Esri Technical Support‌ on this issue, so that we can troubleshoot to see what is missing.
Erwin
jaykapalczynski
Honored Contributor
This is my exact code trying to hit a service of mine....everything is UNDEFINED.
I reached out to ESRI but nothing...
thoughts?
import QtQuick 2.7
import QtQuick.Layouts 1.1
import QtQuick.Controls 2.1
import QtQuick.Controls.Material 2.1
import QtGraphicalEffects 1.0
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
import Esri.ArcGISRuntime 100.2
import "../controls" as Controls
Item {
    property real scaleFactor: AppFramework.displayScaleFactor
    property int baseFontSize : app.info.propertyValue("baseFontSize", 15 * scaleFactor) + (isSmallScreen ? 0 : 3)
    property bool isSmallScreen: (width || height) < units(400)
    property double mousePointX
    property double mousePointY
    property var selectedFeature: null
    property var varWMA: null
    property var vardamageType: null
//    property string inspectorname
    // Create MapView that contains a Map with the Imagery Basemap
    MapView {
        anchors.fill: parent
        wrapAroundMode: Enums.WrapAroundModeDisabled
        Map {
            // Set the initial basemap to Streets
            BasemapStreets { }
            // set viewpoint over The United States
            ViewpointCenter {
                Point {
                    x: -10800000
                    y: 4500000
                    spatialReference: SpatialReference {
                        wkid: 102100
                targetScale: 3e7
            FeatureLayer {
                selectionColor: "cyan"
                selectionWidth: 3
                // declare as child of feature layer, as featureTable is the default property
                ServiceFeatureTable {
                    //url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/DamageAssessment/FeatureServer/0"
                    url: "https://vafwisdev.dgif.virginia.gov/arcgis/rest/services/DGIF_Test/TestRegions/FeatureServer/0"
                    // make sure edits are successfully applied to the service
                    onApplyEditsStatusChanged: {
                        if (applyEditsStatus === Enums.TaskStatusCompleted) {
                            console.log("successfully updated feature");
                    // signal handler for the asynchronous updateFeature method
                    onUpdateFeatureStatusChanged: {
                        if (updateFeatureStatus === Enums.TaskStatusCompleted) {
                            // apply the edits to the service
                            featureTable.applyEdits();
              //  property var car: ({example: ''})
                            return;
                       //vardamageType = selectedFeature.attributes.attributeValue("City_Numbe");
                       varWMA = selectedFeature.attributes.attributeValue("Duplicate");
                       var valuevarWMA = selectedFeature.attributes.attributeValue("County_Nam");
                       //var varFGSymbol = selectedFeature.attributes.attributeValue("FG_Symbol");
console.log("=================================================");
console.log(varWMA);
console.log(valuevarWMA);
console.log(typeof valuevarWMA);
                        // show the callout
                        //damageComboBox.currentIndex = featAttributes.indexOf(vardamageType);
                        notesfield.text = "Value is: " + varWMA;
                        notesfield2.text = "Value is: " + valuevarWMA;
        QueryParameters {
            maxFeatures: 1
        // hide the callout after navigation
        onViewpointChanged: {
            callout.visible = false;
            updateWindow.visible = false;
        onMouseClicked: {
            // reset the map callout and update window
            featureLayer.clearSelection();
            mousePointX = mouse.x;
            mousePointY = mouse.y - callout.height;
            mapView.identifyLayerWithMaxResults(featureLayer, mouse.x, mouse.y, 10, false, 1);
        onIdentifyLayerStatusChanged: {
            if (identifyLayerStatus === Enums.TaskStatusCompleted) {
                if (identifyLayerResult.geoElements.length > 0) {
                    // get the objectid of the identifed object
                    params.objectIds = [identifyLayerResult.geoElements[0].attributes.attributeValue("objectid")];
                    // query for the feature using the objectid
                    featureLayer.selectFeaturesWithQuery(params, Enums.SelectionModeNew);
        //Busy Indicator
        BusyIndicator {
            anchors.centerIn: parent
            height: 48 * scaleFactor
            width: height
            running: true
            Material.accent:"#8f499c"
            visible: (mapView.drawStatus === Enums.DrawStatusInProgress)
    // map callout window
    Rectangle {
        width: row.width + (10 * scaleFactor) // add 10 for padding
        height: 40 * scaleFactor
        radius: 5
        border {
            color: "lightgrey"
            width: .5
        visible: false
        MouseArea {
            onClicked: mouse.accepted = true
        Row {
            anchors {
                verticalCenter: parent.verticalCenter
                left: parent.left
                margins: 5 * scaleFactor
            spacing: 10
// TEXT ON THE POPUP TO MODIFY THE RECORD
            Text {
                Material.accent: "#8f499c"
                text: "damage type " + varWMA
                font.pixelSize: 18 * scaleFactor
            Rectangle {
                radius: 100
                width: 22 * scaleFactor
                height: width
                color: "transparent"
                border.color: "blue"
                antialiasing: true
                Text {
                    text: "i"
                    color: "blue"
                // create a mouse area over the (i) text to open the update window
                MouseArea {
                    onClicked: {
                        updateWindow.visible = true;
    // Update Window
    Rectangle {
        width: 300 * scaleFactor
        height: 300 * scaleFactor
        radius: 10
        visible: false
        GaussianBlur {
            anchors.fill: updateWindow
            source: mapView
            radius: 40
            samples: 20
        MouseArea {
            onWheel: wheel.accepted = true
        Column {
            anchors {
                fill: parent
                margins: 10 * scaleFactor
            spacing: 10
            Row {
                anchors.horizontalCenter: parent.horizontalCenter
                Text {
                    text: "Update Attribute"
                    font.pixelSize: 16 * scaleFactor
            ComboBox {
                width: updateWindow.width - (20 * scaleFactor)
                model: featAttributes
            Text {
              //text: valuevarWMA
               color: "blue"
            TextField {
             // text: varWMA
            Row {
                spacing: 10
                Button {
                    width: (updateWindow.width / 2) - (20 * scaleFactor)
                    text: "Update"
                    function doUpdateAttribute(){
                        if (selectedFeature.loadStatus === Enums.LoadStatusLoaded) {
                            selectedFeature.onLoadStatusChanged.disconnect(doUpdateAttribute);
                           // selectedFeature.attributes.replaceAttribute("TYPE", damageComboBox.currentText);
                           // selectedFeature.attributes.replaceAttribute("WMA", damageComboBox2.text);
                           // selectedFeature.attributes.replaceAttribute("WMA", "Amelia");
                    // once the update button is clicked, hide the windows, and fetch the currently selected features
                    onClicked: {
                        selectedFeature.onLoadStatusChanged.connect(doUpdateAttribute);
                        selectedFeature.load();
                Button {
                    text: "Cancel"
                    // once the cancel button is clicked, hide the window
                    onClicked: updateWindow.visible = false;
    } // End ITEM
ErwinSoekianto
Esri Alum
I checked with Esri Technical Support‌, we don't see any support case related to this issue. We saw other support cases that have been closed.
If this is a mistake please let us know (the support case number if you have it), we would be glad to help.
jaykapalczynski
Honored Contributor
I swear I reached out to them....if not my mistake...I will try once again...
jaykapalczynski
Honored Contributor
I posted this in the Support section...never heard back
https://community.esri.com/thread/233828-update-feature-to-textfield-not-working
jaykapalczynski
Honored Contributor
Is there another location I should forward this to Erwin?
ErwinSoekianto
Esri Alum
Jay, sorry if I was not very clear. I meant to say to contact Esri Technical Support, https://support.esri.com/en/contact-tech-support, we have analysts/specialists who would be able to troubleshoot this with you,
jaykapalczynski
Honored Contributor
OK will try that....was going on your prior post to contact https://community.esri.com/groups/technical-support ...
Got it now...I will place a Support Request and go that route to see if I can get some help....
MUCH Appreciated.
