Show position in the Map Viewer Template(AppStudio for ArcGIS 2.0)
3460
07-06-2017 03:51 AM
KamranYusaf1
New Contributor III
I want to show the position of the device without the user having to press the location button. So when the map is loaded, the position will be showed as default. I can achieve this by starting the locationDisplay, but the view isn't 'zoomed' to the location. When i use the LocationDisplayAutoPanModeRecenter, the map jumps back and forth before zooming to the position. Is there a solution to this?
The code
KaushikMysorekar
New Contributor III
mapView.locationDisplay.start();
mapView.locationDisplay.autoPanMode = Enums.LocationDisplayAutoPanModeRecenter;
mapView.locationDisplay.initialZoomScale(<scale>);
Try doing it this way Kamran. This should work.
KamranYusaf1
New Contributor III
Thanks Kaushik, but the map still jumps back and forth before zooming to the actual location.
by Anonymous User
Not applicable
Hi Kamaran,
Please try this:
 mapView.locationDisplay.start();‍‍
I have created a simple app to test the auto zoom to device location function, it works fine.  Please see the code below.
import QtQuick 2.7
import QtQuick.Controls 2.1
import QtPositioning 5.3
import QtSensors 5.3
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
import Esri.ArcGISRuntime 100.1
App {
    width: 400
    height: 640
    MapView {
        anchors.fill: parent
        Map {
            BasemapImagery {}
            // start the location display
            onLoadStatusChanged: {
                if (loadStatus === Enums.LoadStatusLoaded) {
        // set the location display's position source
        locationDisplay {
            positionSource: PositionSource {
            compass: Compass {}
