Prevent refine location?
629
09-27-2017 07:43 AM
KE
AppStudio Desktop Standard License. Quick Report app.
Is there a way to prevent the user from being able to refine the map location?
nakulmanocha
Hey Kristen,
You can use the following code within MapView component to disable the mouse panning completely on RefineLocationPage. But you need to remember that if the position source is unable to provide end user a good location because of network or gps issues then they cannot be able to pin point the exact location. Basically you will get location totally based on how good the device can fetch the current location.
onMousePositionChanged: {
                mouse.accepted = true;
                return;
Something like this
MapView{
            Layout.preferredWidth: isFullMap? parent.width:(parent.width - 20 *app.scaleFactor)
            Layout.fillHeight: true
            Layout.maximumWidth: isFullMap? Number.POSITIVE_INFINITY: 600 * app.scaleFactor
            anchors.horizontalCenter: parent.horizontalCenter
            property real initialMapRotation: 0
            rotationByPinchingEnabled: true
            zoomByPinchingEnabled: true
            wrapAroundMode: Enums.WrapAroundModeEnabledWhenSupported
                return;
            backgrou.....
// More code below
Nakul
KaushikMysorekar
New Contributor III
Hi Kristen,
Please could you explain what do you mean by refining the map location and why you intend to prevent it?
Thanks
KE
In the Quick Report template, in the RefineLocationPage.qml, I am wondering if there is a way to prevent the user from being able to refine the location (aka move the point from the current location). This would be to prevent users from filing a report in a location that they are not physically located at.
KaushikMysorekar
New Contributor III
Thanks for providing additional details Kristen. I will do some research and let you know if could figure this out.
nakulmanocha
Hey Kristen,
                return;
Something like this
MapView{
                return;
            backgrou.....
// More code below
Nakul
