Login to Survey123 with Portal user using username and password from qt
391
10-29-2021 11:27 AM
sakilesa
I am developing a Survey123 form app using ArcGIS AppStudio. As the form is not public it is needed to login with username and password from QT. User will not login by provide any credentials.
Is there any way?
Regards,
Sakil Ahmed
Esri South Asia
ErwinSoekianto
Esri Alum
@sakilesa
I don't think you need the credentials from Qt, the credentials you need are to login to ArcGIS Online or Enterprise depending on where you create the Survey123 Form.
https://community.esri.com/t5/arcgis-survey123-blog/extending-survey123-part-1-white-labeling/ba-p/8...
Thank you,
Erwin
