I am trying creating a new version of the AAB file and publish it. And it not finish the process.
Bellow a screenshot of the versions.
around 99% progress I am getting the error message bellow.
... the first error that I for was related with Framework.Sensors. I have commented the line //import ArcGIS.AppFramework.Sensors 1.0 and now I am getting the error above.
I spent the whole day trying to find the lines where I can disable it and I couldn't find it. Attached I am sent the log details. I hope someone helps me understand this problem.
obs. If I change it to .apk its works fine. but .aab not works.
thanks
Same here. It seems AppFactory is broken for AAB. I have tried everything and submitted a case hoping for a resolution quickly.
Also, it's for any app. I even tried a "hello world" app, and had the same issue. It seems to only happen once you try to use a signed keystore. If no keystore everything seems to work.
Hi Ray. Yes, I've seen your post. But no replay and I opened a new one adding more detail hoping that someone will help us.
I uncheck the Sign Package, it works but the Google Play Console not accept it. The app bundle need be signed. I have created a new app from template to test. And same error. Appstudio has chganged something from last days. And I have could not find any documentation about it.
So hard, I need to publish a new version of my application soon.
Hello @CrisjovanoGumaraes,
We are aware of an issue with Cloud Making AAB files and are working towards a resolution. We expect to have a fix the first week of January 2022. We will keep you updated if the fix is available any sooner.
Best regards,
Trevor
Good to know you are already aware of the issue. Thanks Trevor.
The issue has now been resolved and you should be able to use cloud make to build AAB files.
Best,
Trevor
Thanks Trevor. Now is working fine.
Hi @TrevorFrame,
I'm getting the same issue, I'm not able to create an aab bundle file for android (also doesn't work for ARM APK).
Can you provide support for this issue?
Carlos Carvalho
Hi @CarlosCarvalho ,
I noticed your other post regarding jarsigner: key associated not a private key and think this cloud make issue might be related. Please use the other thread for continued responses.
Best,
Trevor Frame
Hi @TrevorFrame
I am still getting what looks like the same error trying Cloud Make. I have attached the full error response I get. Any assistance or guidance would be appreciated.
Gracias,
Mysti
