We are excited to announce the release of ArcGIS AppStudio Version 5.1. This release rolls out many new features and enhancements to help you and your team create rich experiences in building and distributing cross-platform native apps. Read this blog to learn more.
Bug fixes and enhancements:
BUG-000140588 | Setting the 'Portal sort field' property on a Map Viewer Template (5.0) app has no impact on the order of the Webmaps listed in the app gallery. |
BUG-000140450 | BUG-000140450 The order of the layers in the offline map areas in ArcGIS AppStudio is reversed compared to in the web map. |
BUG-000140254 | Layer names in Content and Legend are not equivalent as defined in Web Map when viewing an Offline Map Area in ArcGIS AppStudio Player. |
BUG-000134146 | Setting Window mode to 'Minimized' in the ArcGIS AppStudio Settings dialog does not work. |
BUG-000133765 | Empty body observed on the Delete method from NetworkRequest. |
BUG-000139666 | Downloading an offline map with ArcGIS AppStudio MapViewer does not include the vector basemap. |
Learn more about AppStudio:
