I have created a silverlight 4 GIS application. When I run this application in our dev environment I have no error what so ever. But When I run the application in our test environment I get the error Code 4004.
The only different between Test and dev is that the map services is secure, so I add the following users: gisadmin, gisusers, Guess, IIS-Guest, Domain01 - Everyone.
Also, I have check IIS and I remove check window authentication for ArcGIS/rest and ArcGIS/services (and all subfolder under ArcGIS).
I also have my clientaccess file which works for dev and test for cross domain. This file is completely open for all http or uri.
I believe the problem is getting access to the map services, but I do not know what other local user or Domain user I need to add.
Any suggestion?
Thanks
Luis Acedo
