I just installed the silverlight 4 tool for visual studio,and the silverlight developer, but the map is alway invisible when running the app,why? I have installed the arcgis server to the directory :H:\Program Files ,and my clientaccesspolicy.xml is config with: [HTML]<?xml version="1.0" encoding="utf-8" ?> <access-policy> <cross-domain-access> <policy> <allow-from http-request-headers="*"> <domain uri="*"/> <domain uri="http://*"/> </allow-from> <grant-to> <resource path="/" include-subpaths="true"/> </grant-to> </policy> </cross-domain-access> </access-policy> [/HTML] I event create a directory "C:\inetpub\wwwroot" and copy the files "clientaccesspolicy.xml" and "crossdomain.xml" inside. what is the other stuff I shoul do then? Thanks very much.
Hello, I have a same problem as I could not see my layers when I run my silver light application. Could you please help me that what should i do.
Prakash City of Los Angeles
perhaps it's the map extend is too large or too small,that is the ordinary issue. I have just posted above that I solved the issue by re-install my vs.Or you can repair and re-install the relate silvelight ware. That is what did.Maybe you can check your "clientaccesspolicy.xml " first.
