How to pan and zoom to selected point correctly?
4779
6
01-30-2015 01:40 AM
AnatoliiTerentiev
Occasional Contributor III
Dear Gurus!
Excuse for question, but I can't understand why don't work this block:
 myMap.PanTo(selectedPoint);
 myMap.ZoomToResolution(140, selectedPoint);
when in xaml :
<esri:Map x:Name="myMap"  Extent="3200000,8550000,4250000,10100000">
       <esri:OpenStreetMapLayer ID="OSMLayer" Style="Mapnik" />
      <esri:ArcGISDynamicMapServiceLayer ID="RK"
                            Url="http://localhost:6080/ArcGIS/rest/services/karelia/MapServer" />
      <esri:FeatureLayer    ID="routes_osm"
                            Url="http://localhost:6080/ArcGIS/rest/services/karelia/MapServer/1" >
                </esri:FeatureLayer>
</esri:Map
PanTo - works just as expected, and after the addition of the second line- the result is not clear
Thanks in advance!
DominiqueBroux
Esri Frequent Contributor
Due to animation PanTo and ZoomToResolution are asynchronous operations that give undefined results if they are executed simultaneously.
One option may be to create a method that do both actions at the same time (e.g. centerAndZoom method)
DominiqueBroux
AnatoliiTerentiev
Excellent, Dominique! That is just what I wanted!
AnatoliiTerentiev
And If not difficult - how do likewise for panTo(geometry) (line or polygon)?
DominiqueBroux
For panning/zooming to a line or polygon, you have the following options:
   - use PanTo if you want to keep the map resolution
   - use the former CenterAndZoom with geometry.Extent.GetCenter() if you want to zoom at a predefined resolution (but not sure the full geometry will be inside the map extent)
   - or most simple, use ZoomTo(geometry) or something like ZoomTo(geometry.Expand(1.2))
AnatoliiTerentiev
It's clear, but there were doubts that there is a certain algorithm for computing the resolution depending on the size of the object.
AnatoliiTerentiev
When I tried to get initial state of the map as follows
        private void setInitialMap()
            centerAndZoom(myMap, initCentrPoint, InitMapResolution);
            Thread.Sleep(100);
        private void centerAndZoom(ESRI.ArcGIS.Client.Map map, ESRI.ArcGIS.Client.Geometry.MapPoint mapPoint, double resolution)
            double ratio = 1.0;
            if (map.Resolution != 0.0)
                ratio = resolution / map.Resolution;
            if (ratio == 1.0)
                map.PanTo(mapPoint);
            else
                ESRI.ArcGIS.Client.Geometry.MapPoint mapCenter = map.Extent.GetCenter();
                double X = (mapPoint.X - ratio * mapCenter.X) / (1 - ratio);
                double Y = (mapPoint.Y - ratio * mapCenter.Y) / (1 - ratio);
                map.ZoomToResolution(resolution, new ESRI.ArcGIS.Client.Geometry.MapPoint(X, Y));
the result was negative, as long as I do not put a slight delay 100 ms. What may be the reason?
