Dear Gurus!
I want to see what I can do with arcgis when working without Silverlight.
For example - how I can reproduce next silverlight code
<esri:Map x:Name="myMap" Background="White" WrapAround="true" Extent="3200000,8500000,4250000,10130000" MouseClick="Map_MouseClick" > <esri:OpenStreetMapLayer ID="OSMLayer" Style="Mapnik" /> <esri:ArcGISDynamicMapServiceLayer ID="MyMap" Url="http://server:6080/ArcGIS/rest/services/karelia/MapServer" /> </esri:Map>
in ASP without using silverlight?
Solved! Go to Solution.
I have an app I created in .NET using the JavaScript API. Here is some sample code of how I control JavaScript related items using .NET: SOA-Final/default.aspx.vb at master · csergent45/SOA-Final · GitHub
If I understand correctly, then something like this
Thank you, Chris, I did not notice your reply in time!
No problem. If you are interested, I created a group for .NET developers here: .NET and the Esri JavaScript API
I develop in both just the JavaScript API as well as .NET integration with the JavaScript API.
Thank you, certainly join!
Where I can download Arcgis API for Javascript? In this SDK Downloads | ArcGIS for Developers I did not see download link only for JavaScript
Sorry, I found it How I can download JavaScript API ?
I see you have the information on the other group.
In any case - thanks you very much, Chris!!!
