check vehicle location inside or outside
1724
09-07-2014 07:58 PM
JulieBiju
Hi all,
I need to do the below task. How can I do this?
we have a vehicle location with longitude and latitude  values. In a map we created a special layer named geofenceLayer. I need to check when this vehicle is coming in and going out from this particular layer. Is it possible to do?
AsserSwelam1
Hi Julie,
You can use Envelope.Intersects method.
Get your vehicle location extent and check if it is intersects with the geofecneLayer.
Something like this
Polygon geoFenceArea = geofenceLAyer.Graphics[0] as Polygon;
if(vehicleLocation.Extent.Intersects(geoFenceArea.Extent))
     //The vehicle is in
else
     //The vehicle is out
Hope this helps.
Asser
