add symbol and System.Runtime.Serialization error
4693
01-07-2015 08:56 AM
MariaMaldini
hello , I am working on one of Esri silverlight samples that assign symbol for point features. when i add following codes to assign symbol to point layer :
            <esri:PictureMarkerSymbol x:Key="DefaultClickSymbol" OffsetX="11" OffsetY="39" Source="/Assets/images/i_pushpin.png" />
            <esri:SimpleFillSymbol x:Key="DefaultBufferSymbol" Fill="#660000FF" BorderBrush="Blue" BorderThickness="2"  />
i encounter with this error:
Error1Could not load file or assembly 'System.Runtime.Serialization, Version=5.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e' or one of its dependencies. The system cannot find the file specified.C:\TEMP\featureEditing - Copy\featureEditing\MainPage.xaml11featureEditing
and i added following references:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Net;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Animation;
using System.Windows.Shapes;
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Geometry;
using ESRI.ArcGIS.Client.Toolkit;
using ESRI.ArcGIS.Client.Toolkit.DataSources;
using System.Runtime.Serialization;
using ESRI.ArcGIS.Client.Bing;
using system.ServiceModel.Syndication;
using ESRI.ArcGIS.Client.WebMap;
i read different pages about this problem but i could not find any solution.
Is there anybody who can help me? thanks in advance
DominiqueBroux
Esri Frequent Contributor
A reference to System.Runtime.Serialization has to be added manually to your project.
See an answer to a similar issue:  Re: Could not load file or assembly 'System.Runtime.Serialization, Version=2.0.5.0
MariaMaldini
in my first message, i mentioned the references in my program and System.Runtime.Serialization is added already.
but still i encounter with the mentioned error.
MariaMaldini
actually i did not find System.Runtime.Serialization. i have just "System.Runtime.Serialization.Json".
MariaMaldini
so i had to add System.Runtime.Serialization manually to code behind part. but as i told already it does not work and i face with mentioned problem.
using System;
using System.Linq;
using System.Net;
using ESRI.ArcGIS.Client.Tasks;
using ESRI.ArcGIS.Client.Symbols;
MariaMaldini
I found it . i was looking to find it in extensions tab.whereas it was in framework tab. thanks it solved.
