Working with Geotagged Images
938
10-28-2010 11:40 AM
BrianGustafson
Does anyone have any sample code or even know if it is possible to use geotagged images with the silverlight api.  I had the idea to have a user drag an image onto the map and then build a picturemarkersymbol where the mouseup event occured.  Is there a better way to do this and also store the geotagged images on the client so they can retrieve them later?
dotMorten_esri
Esri Notable Contributor
I'm afraid you would have to write your own image header parser to do this in Silverlight. I don't think it has the API's necessary to do this (.NET 2.0+ does though). But if you could get over the hump of reading the header, it should be pretty easy from there.
This API could perhaps be a good start: http://imagetools.codeplex.com/
