Use jpg instead of PNG for WMS Service.
2685
01-04-2012 07:57 AM
caseycupp
I am getting PNGs for my WMS Layers.
according to this, JPG is recommended.
http://blogs.esri.com/Dev/blogs/arcgisserver/archive/2009/09/03/Achieving-smooth-transitions-with-ad... " JPEG is by far the best image format for cached map services that contain aerial photography to be used in a Web application. "
I don not see where to see a FORMAT property for ESRI.ArcGIS.Client.Toolkit.DataSources.WmsLayer.
Is there a way to request the WMS as a JPG.
Casey
JenniferNery
If you are using v2.3 and up, WMSLayer has ImageFormat and SupportedImageFormats property that you can use. You can select "image/jpeg" if it is one of the supported format.
