This link, Code Attachment download the contents of the template with the introductio
3721
10-16-2011 04:45 AM
liutao
I am a concerned fan of ArcGIS!
     This link, Code Attachment download the contents of the template with the introduction of the match.
     http://www.arcgis.com/home/item.html?id=eaa6e54219684ca0bef9f5056662f6d3
     Where should download this template ?   Email:165113@qq.com
JenniferNery
You can add comments to that link to ask the contributor. I'm not sure if they used any of the templates provided here: http://help.arcgis.com/en/webapi/silverlight/samples/TemplateGalleryWeb/start.htm
DarinaTchountcheva
Occasional Contributor II
The Code Attachment is only a sample of how the MapTip was designed (without the chart part). This sample uses the ESRI Standard Map Application, which is integrated in Visual Studio when the ArcGIS Silverlight API is installed (it can be also downloaded from the link below, it is the Standard Application Template).
The complete Crime Map application is a combination of two of the Templates provided by ESRI (the link posted by Jeniffer):
The two templates are the Glass and the Frosted Tab Menus.
Please, let me know which template you are interested in, the MapTip sample, or the Crime Map application.
Darina
