Several    Questions    about    "ArcGIS  For  Silverlight"
985
6
05-22-2012 08:28 PM
chengchao
One:
      What  map  does  "ArcGIS For Silverlight" use ?   "Bing"   map?
Two:
      Can   "ArcGIS For Silverlight"   use  custom  3D  map?
Three:
     Does  "ArcGIS For Silverlight"   charge?
vipulsoni
One:
Two:
Three:
1. ArcGIS for Silverlight can use maps from ArcGIS Server REST services and other basemaps from ArcGIS online and also from Microsoft Bing.
2. For custom 3D Maps I am not sure , since it has been done in one of the samples.
3. ArcGIS for Silverlight is a freely downloadable API from ESRI.
dotMorten_esri
Esri Notable Contributor
1: What ever you want, Bing maps, ArcGIS Server/Online, OpenStreetMap, WMS, WMTS, [Insert custom layer type here]
2: No.
3: It depends. For some uses it's free, for others it's not. You should contact your local esri dealer for specific details on licensing and price. Also when using Bing Maps, you will need to license that data from Microsoft as well.
chengchao
Thanks  a   lot...
    One:   Should use "ArcGIS Server REST services"  be charge ?    What service is free?
    Two:   Must call service?    Create your own map not line?
chengchao
2: No.
Thanks a lot...
One: Should use "ArcGIS Server REST services" be charge ? What service is free?        Bing maps service is not free???
Two: Must call service? Create your own map not line?    Like the 2D custom maps , not  3D...
chengchao
Thanks a lot...
ArcGis service what is free ? I have no money, just want to try development.
Question Two:
Meaning is using our own pictures as a map. It's ok???
JenniferNery
