how to zoom to initial extent?
2752
09-13-2012 08:51 AM
DanielSchatt
I've added an ESRI image service and I'm using the navigation tool from the "Navigation" sample here. When I click the "Full Extent" on the navigation tool, it zooms out to the entire world (the full extent in the image service) instead of the Extent set in my map element (which is my initial extent).  Does anyone know how I link the "Full Extent" of the nav tool to the Extent set in my map element?  Thanks!
Dan
JoshuaCorcoran
You could use WebClient to query the Rest service get the inital extent properties and then call Map.ZoomTo and pass in the extent you grabbed from rest.
DanielSchatt
thanks Joshua, problem is I don't know how to access the "Full Extent" event of the navigation tool which is the event that occurs when you click the full extent button within that navigation tool.. there doesn't appear to be any property that corresponds to that.
DominiqueBroux
Esri Frequent Contributor
