How to show layers in Pulkovo 1942 in OpenStreetMap?
683
01-28-2014 02:13 AM
AnatoliiTerentiev
Dear Gurus!
I have some layers in Pulkovo1942
<!-- Map Control -->
<esri:Map x:Name="Map" Background="White" WrapAround="true" Extent="6095000,6810000,6900000,7258000">
     <esri:ArcGISDynamicMapServiceLayer ID="BaseLayer"
        Url="http://terentievai:6080/ArcGIS/rest/services/rk/MapServer" />
</esri:Map>
And now I need to use OpenStreetMap , which is in EPSG:4326. I think something like:
<esri:Map x:Name="Map" Background="White" WrapAround="true" Extent="3000000,8000000,4000000,10008000">
        <esriOSM:OpenStreetMapLayer ID="BaseLayer" Style="Mapnik"  />
</esri:Map>
<esri:Attribution Layers="{Binding ElementName= Map, Path=Layers}" />
How can I combine these two coordinate systems?
AnatoliiTerentiev
How to reproject map from one coordinate system to another?
DominiqueBroux
Esri Frequent Contributor
DynamicMapService layers are automatically projected in the map Spatial Reference by the server.
Set 2 layers in your map:
  1. OpenStreetMapLayer
  2. DynamipMapServiceLayer
And that's it.
Sidenote: OpenStreetMap is not in EPSG:4326 but in WebMercator. Your map initial extent coordinates must use this SR.
