How to see attribute values when binding to Feature Layer
1726
07-27-2011 05:05 AM
JohnLove
I have implemented the "Configurable Silverlight Template Viewer for ArcGIS 2.1"
(here's the link http://www.arcgis.com/home/item.html?id=67f62c5c30cc4b3ca942068e404c442c ) and I need to change the background color of a bound Label in the map tip ( I changed the TextBlock to a label). I understand the IValueConverter pretty well but I'm not sure how to read an attribute value from the binding in order to determine the color to use.
DominiqueBroux
Esri Frequent Contributor
The datacontext of the MapTip is set to the 'Attributes' of the current graphic, Attributes being a Dictionary.
So a binding such as <TextBlock Text={Binding [Label]} /> is working by supposing you have an attribute called 'Label' that you want to display.
If you have an attribute storing a Brush (let's call it BackgroundBrush), you can directly set the background color by:
<TextBlock Text={Binding Label} Background={Binding [BackgroundBrush]}/>
If your attribute is just a color or a string representing a color, you need to write a value converter to convert the color to a brush:
<TextBlock Text={Binding Label} Background={Binding [BackgroundColor], Converter={StaticResource myColorConverter}/>
JohnLove
Thank you for your reply Dominique,
The problem I'm having is due to TextBlocks being dynamically being generated with each one being assigned a different value by binding to the PropertyPath.
I cannot figure out how to test each textblock as it is created in order to set it's color based on the attribute value (i.e. if the value <= 50 the color = green else the color = red). I have written a ValueConverter that returns a brush based on the value passed into it. I just don't know how to get the value to pass into it.
Please see code below:
private PopupWindow CreateTipWindow(FeatureLayerInfo lyrInfo, List<string> outFields)
            Dictionary<string, string> aliases = new Dictionary<string, string>();
            foreach (Field f in lyrInfo.Fields) { if (f.Name != lyrInfo.DisplayField) aliases.Add(f.Name, f.Alias); }
            PopupWindow tipWindow = new PopupWindow() { ShowArrow = false, ShowCloseButton = false, };
            tipWindow.Content = CreateFeatureTipContent(outFields, aliases);
            tipWindow.Background = this.myTaskbarWidget.Background;
            Binding titleBinding = new Binding() { Path = new PropertyPath(string.Format("[{0}]", lyrInfo.DisplayField)) };
            tipWindow.SetBinding(PopupWindow.TitleProperty, titleBinding);
            if (lyrInfo.Name == "Building")
                tipWindow.TitleFormat = "Installation ID" + ": {0}";
            else
                tipWindow.TitleFormat = lyrInfo.Name + ": {0}";
            return tipWindow;
        private FrameworkElement CreateFeatureTipContent(List<string> fields, Dictionary<string, string> aliases)
            StackPanel stackBox = new StackPanel() { Margin = new Thickness(4, 1, 4, 1), Orientation = Orientation.Vertical };
            foreach (string field in fields)
                if (aliases.Keys.Contains(field))
                    TextBlock valueBlock = new TextBlock() { TextWrapping = TextWrapping.NoWrap };
                    Binding valueBinding = new Binding() { Path = new PropertyPath(string.Format("[{0}]", field)), StringFormat= aliases[field] + ": {0}" };
                    valueBlock.SetBinding(TextBlock.TextProperty, valueBinding);
                    stackBox.Children.Add(valueBlock);
            return stackBox;
        private void MapControl_MouseClick(object sender, Map.MouseEventArgs mouseEventArgs)
DominiqueBroux
You can set a background binding by code.
After your code:
you can add code like:
Binding colorBinding = new Binding{
    Converter = new MyColorConverter()
valueBlock.SetBinding(TextBlock.ForegroundProperty, colorBinding );
Your converter will get the value of the field as input value (due to binding to [<field>]).
Note : in Silverlight the TextBlock has no BackGround property, so to set the background you will need to surround the textblock with a container or use the 'Label' control.
