Hi All,
I am having an issue of highlighting individual graphics in a cluster. I have plotted some points on the map using flare cluster symbol. And corresponding records of those points are displaying in a grid. Now when I select any record on the grid it will pass some ID which will then check all the graphics in the point layer and if it finds any match it will highlight that point on the map. It is working fine where no cluster graphics are there. However, when the ID is matching with any cluster graphics on that case I am not able highlight that graphic.
is it possible to highlight any individual graphic in a cluster?
if it is not possible, is there any way to highlight / blinking the center graphics of a cluster?
Any help concerning this will be highly appreciated!!
Thank you for your time.
Regards,
Niladri Banerjee,
Sr. Software Engineer
PointCross Inc
