Freehand draw mode may not be working
2726
06-11-2013 12:48 PM
LuisGarcia2
Occasional Contributor II
I am using a Draw object to allow my clients to mark some graphics on a map. I set up the draw mode to work as DrawMode.Freehand. The idea is to allow the client to draw a freehand shape on tight spaces (clutter graphics) so they can select what they are interested in. Of course the result is an asymmetric polygon. Now, I have noticed that when I process the DrawComplete event I may not end up exactly with the graphics I had "lasso." It looks more like if the geometry was interpreted as a rectangle. Please, take a look at the pictures I am attaching and let me know if I need to do any other setting to process my event correctly. In the pictures you can see the difference between what I selected (with the freehand drawing) and what ended up selected (in green).
If there is an example of this somewhere, please, let me know.
Thanks!
by Anonymous User
Not applicable
Original User: lgarcia3
I think I got my answer (partially at least) after using the debugger and seeing the DraxComplete event handler. from the line:
myDrawObject_DrawComplete(object sender, DrawEventArgs args)
The args object contains the geometry which in my case is a Polyline. When I see the polyline, it may have up to 500 lines that make the geometry. This geometry also has an extent which is what I am processing... and in that case, yes, the result is a rectangle/square kind of thing; not the exact shape I was hoping for. So, point being how can I convert this to a shape that I can process and find only the markers inside it so I can mark them.
Thanks!
LuisGarcia2
I tried creating a Polygon out of the polyline created with the freehand draw. Still the extent is exactly the same as before. Here is the code:
               if (args.DrawMode == DrawMode.Freehand) {
                    ESRI.ArcGIS.Client.Geometry.Polyline polyline = (ESRI.ArcGIS.Client.Geometry.Polyline)args.Geometry;
                    ESRI.ArcGIS.Client.Geometry.Polygon polygon = new ESRI.ArcGIS.Client.Geometry.Polygon();
                    polygon.Rings = polyline.Paths;
                    ESRI.ArcGIS.Client.Geometry.Envelope envelope= polygon.Extent;
So, (please, correct me if I am wrong and there is a different way I don't know) that tells me that for this to work the way I intend it there has to be a different Envelope object that accepts polygons??
Thanks!
by Anonymous User
Not applicable
I found something HERE about buffer areas that look similar to what I want to do. Any one familiar with this buffer area? Anyone knows if this could help me solve my problem?
Thanks!
