FeatureDataForm - 4 to 5 tabs to load columns?
736
11-13-2012 11:51 AM
Ravichandran_M_Kaushika
dear Readers,
Questions:
1. how to put fields into different tabs in a feature data form?
2. is it possible to change the text fields to a dropdown that loads from a support table in sql server 2008 r2 (attributes only) in a feature data form.
DETAILS:
thank you taking the time to read this post.  We have a feature layer that has 78 or more columns.  User have requested the fields to be put into 5 to 6 tabs based on the information each column holds.  currently the app is of the following configuration:
1. esri api 3.0 (silverlight 5.x)
2. development lang c# - visual studio 2010 with latest sp.
3.  REST etc from 10.1 (sql server 2008 r2 with spatial etc that works with esri).
the application was started with minimal template - then 'modified' to the glass template.
featurelayers records load in the grid and the application saves the data to the server using explicit save - since editing in the grid is cumbersome users want columns grouped into different tabs.
Users want a 'support table' for many of the columns (displayed as dropdown) to improve data accuracies.
http://forums.arcgis.com/threads/68615-Cannot-Select-From-Domain-in-Attribute-Editor?highlight=featu... - this link talks about layer getting values from domain table - but features are deleted or users are not able to derive benefit because all features have been deleted.
while I get some suggestions, i will closely look into this thread: http://forums.arcgis.com/threads/21714-Editing-Tables-in-Feature-Service-with-Silverlight-4?highligh...
regards
ravi.
