using System;
using System.Collections.Generic;
using System.IO;
using System.Linq;
using System.Text;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Tasks;
namespace ExportTest
public partial class MainPage : UserControl
public MainPage()
InitializeComponent();
void QueryButton_Click(object sender, RoutedEventArgs e)
QueryTask queryTask =
new QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5");
queryTask.ExecuteCompleted += QueryTask_ExecuteCompleted;
queryTask.Failed += QueryTask_Failed;
ESRI.ArcGIS.Client.Tasks.Query query = new ESRI.ArcGIS.Client.Tasks.Query();
query.Text = StateNameTextBox.Text;
query.OutFields.Add("*");
queryTask.ExecuteAsync(query);
void QueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
FeatureSet featureSet = args.FeatureSet;
if (featureSet != null && featureSet.Features.Count > 0)
QueryDetailsDataGrid.ItemsSource = args.FeatureSet;
else
MessageBox.Show("No features returned from query");
private void QueryTask_Failed(object sender, TaskFailedEventArgs args)
MessageBox.Show("Query execute error: " + args.Error);
private void Excel_Click(object sender, RoutedEventArgs e)
DataGridExtensions.ExportDataGrid(QueryDetailsDataGrid, null);
public static class DataGridExtensions
public static void Export(this DataGrid dg, List<string> excludedColumns)
ExportDataGrid(dg, excludedColumns);
public static void ExportDataGrid(DataGrid dGrid, List<string> excludedColumns)
SaveFileDialog objSFD = new SaveFileDialog() { DefaultExt = "csv", Filter = "CSV Files (*.csv)|*.csv|Excel XML (*.xml)|*.xml|All files (*.*)|*.*", FilterIndex = 1 };
if (objSFD.ShowDialog() == true)
string strFormat = objSFD.SafeFileName.Substring(objSFD.SafeFileName.IndexOf('.') + 1).ToUpper();
StringBuilder strBuilder = new StringBuilder();
if (dGrid.ItemsSource == null) return;
if (dGrid.HeadersVisibility == DataGridHeadersVisibility.Column || dGrid.HeadersVisibility == DataGridHeadersVisibility.All)
var listFields = from col in dGrid.Columns
where excludedColumns == null || !excludedColumns.Contains(col.Header.ToString())
select col.Header.ToString();
BuildStringOfRow(strBuilder, listFields, strFormat);
foreach (Graphic data in dGrid.ItemsSource)
select GetValue(col.GetCellContent(data));
StreamWriter sw = new StreamWriter(objSFD.OpenFile());
if (strFormat == "XML")
//Let us write the headers for the Excel XML
sw.WriteLine("<?xml version=\"1.0\" encoding=\"utf-8\"?>");
sw.WriteLine("<?mso-application progid=\"Excel.Sheet\"?>");
sw.WriteLine("<Workbook xmlns=\"urn:schemas-microsoft-com:office:spreadsheet\">");
sw.WriteLine("<DocumentProperties xmlns=\"urn:schemas-microsoft-com:office:office\">");
sw.WriteLine("<Author>Arasu Elango</Author>");
sw.WriteLine("<Created>" + DateTime.Now.ToLocalTime().ToLongDateString() + "</Created>");
sw.WriteLine("<LastSaved>" + DateTime.Now.ToLocalTime().ToLongDateString() + "</LastSaved>");
sw.WriteLine("<Company>Atom8 IT Solutions (P) Ltd.,</Company>");
sw.WriteLine("<Version>12.00</Version>");
sw.WriteLine("</DocumentProperties>");
sw.WriteLine("<Worksheet ss:Name=\"Silverlight Export\" xmlns:ss=\"urn:schemas-microsoft-com:office:spreadsheet\">");
sw.WriteLine("<Table>");
sw.Write(strBuilder.ToString());
sw.WriteLine("</Table>");
sw.WriteLine("</Worksheet>");
sw.WriteLine("</Workbook>");
sw.Close();
private static string GetValue(FrameworkElement frameworkElement)
return frameworkElement == null ? null
: (frameworkElement is TextBlock ? (frameworkElement as TextBlock).Text : frameworkElement.ToString());
private static void BuildStringOfRow(StringBuilder strBuilder, IEnumerable<string> lstFields, string strFormat)
switch (strFormat)
case "XML":
strBuilder.AppendLine("<Row>");
strBuilder.AppendLine(String.Join("\r\n", lstFields.ToArray()));
strBuilder.AppendLine("</Row>");
break;
case "CSV":
strBuilder.AppendLine(String.Join(",", lstFields.ToArray()));
break;
private static string FormatField(string data, string format)
switch (format)
case "XML":
return String.Format("<Cell><Data ss:Type=\"String\">{0}</Data></Cell>", data);
case "CSV":
return String.Format("\"{0}\"", data.Replace("\"", "\"\"\"").Replace("\n", "").Replace("\r", ""));
return data;
return graphic.Attributes[path] == null ? string.Empty : graphic.Attributes[path].ToString();
private static string GetValue(DataGridColumn col, Graphic graphic)
            if (col is DataGridBoundColumn)
                DataGridBoundColumn column = col as DataGridBoundColumn;
                if ((column.Binding != null) && (column.Binding.Path != null))
                    string path = column.Binding.Path.Path;
                    if (!string.IsNullOrEmpty(path))
                        var att = Regex.Replace(path, ".*\\[(.*)\\]", "$1");
                        return graphic.Attributes[att].ToString();
            return string.Empty;
return graphic.Attributes[att] == null ? string.Empty : graphic.Attributes[att].ToString();
        public static void Export(this FeatureDataGrid dg, IEnumerable<Graphic> graphics, List<string> excludedColumns)
            ExportDataGrid(dg, graphics, excludedColumns);
        public static void ExportDataGrid(FeatureDataGrid dGrid, IEnumerable<Graphic> graphics, List<string> excludedColumns)
                                     select FormatField(col.Header.ToString(), strFormat);
                foreach (Graphic graphic in graphics)
                    var listValues = from col in dGrid.Columns
                                     select FormatField(GetValue(col, graphic), strFormat);
                    BuildStringOfRow(strBuilder, listValues, strFormat);
                sw.Close();
            switch (strFormat)
                case "XML":
                    break;
                case "CSV":
                    break;
            switch (format)
                case "XML":
                case "CSV":
            return data;
resultFeature.Attributes.Add("OWNADDRESS_FULL",
                            resultFeature.Attributes["OWNADDRESS"] + "\r" + (resultFeature.Attributes["OWNCITYST"] + " " + resultFeature.Attributes["OWNZIPCODE"]).Trim()); // + "\r" + resultFeature.Attributes["OWNCOUNTRY"]);
		Sorry I zipped the wrong file :
First off, thank you for providing this code. It works pretty well for me if I am not exporting more than 10-15 records at a time. Anymore than that then it starts either dropping data or wont save. Screencap of an exported csv. Are there limits to how much data can be exported? I have found that if I export data from a datagrid that has fewer columns I am able to export more records before it either doesn't work or stops populating columns.
