Definition of the nearest object
1205
04-29-2014 05:58 AM
AnatoliiTerentiev
Dear Guru!
Is there some tool in arcgis API for silverlight for identifying the nearest town (or other object) with the definition of distance and azimuth to it?
AsserSwelam1
You can use Find Nearest Geoprocessing Task as here http://resources.esri.com/help/9.3/arcgisserver/apis/silverlight/help/find_task.htm and after you get your nearest feature you can show its attributes.
Or you can create a buffer with the distance you want for your center feature and using this buffer polygon to get any other feature (town) intersects with this buffer.
Asser
AnatoliiTerentiev
I need to solve the problem  programmatically. I use the C#  and arcgis API for silverlight, MSSQL server 2012. To the x,y - event in the x,y-table  is necessary to find the nearest settlement and similar tasks.
