X/Y coordinates in pandas dataframe to map
10919
12
07-25-2017 07:20 AM
DavidRalston
New Contributor II
Is there a way to add x/y coordinate columns in a pandas dataframe to a map using the arcgis python api in jupyter notebook?
RohitSingh2
Yes, an example is below:
locations = []
path = r'C:\xc\Presentations\GeoPython\Watson\insulators'
# find locations of broken insulators
for file in listdir(path):
    filepath = path + '\\' + file
    if is_broken(filepath):
        locations.append(get_location(filepath))
# import into ArcGIS as a layer
df = pd.DataFrame.from_records(locations)
df.columns = ['x', 'y']
broken_insulators = gis.content.import_data(df)
m.add_layer(broken_insulators)
I have defined get_locations to return longitude, latitude:
def get_location(filename):    #...         return lon, lat
DavidRalston
New Contributor II
Awesome! My code looks like this:
gis = GIS()
data[['Longitude_X', 'Latitude_Y']]
layer = gis.content.import_data(x)
print (layer)
map = gis.map('UK')
map.add_layer('layer')
map
data is a pandas dataframe
<FeatureCollection>
The layer is a feature collection, but the lat long data doesn't show on the map. Possible reasons why?
RohitSingh2
Try setting the columns of your dataframe to x and y. The following works:
from arcgis.gis import *
import pandas as pd
gis = GIS()
m = gis.map('UK')
locations = [(52.47867, -1.90848),
 (51.50642, -0.12721),
 (53.79480, -1.54653),
 (53.47959, -2.24874)]
df.columns = ['y', 'x']
cities = gis.content.import_data(df)
m.add_layer(cities)
m
I get the following output:
ManushiMajumdar
Is there a way to do this with a df that has more than 1000 rows? This script throws an error for that case..
IonutAlixandroae4
If it`s something that deals with memory you should give it a try with increasing the iopub_data_rate_limit; i had this kind of problem with viewing more that a few pictures.
iopub rate limits are too low by default, for visualization-heavy projects · Issue #2287 · jupyter/n...
jupyter notebook --NotebookApp.iopub_data_rate_limit=10000000000
Ionut
ManushiMajumdar
Thanks Ionut!
It still gives me the error (Error Code: 401): UnAuthorized
RohitSingh2
If there are more than 1000 rows, you should convert it to a SpatialDataFrame. You can do it like this:
df['SHAPE'] = df.apply(lambda row : arcgis.geometry.Geometry({'x': row['x'], 'y': row['y']}), axis=1 )
sdf = SpatialDataFrame(df)
layer = gis.content.import_data(sdf, title='My Data')
m.add_layer(layer) # add to map
find_nearest(layer, ...) # use for analysis
ManushiMajumdar
Thanks Rohit!
The exact same code snippet is giving me an error -
RuntimeError: Service name 'a' already exists for 'bkrWlSKcjUDFDtgw'
I don't know how to debug it since I don't have services with that name/id..
RohitSingh2
There's a bug in import_data that creates a service by the name 'a' the first time it runs... the fix will be in the next update, but as a workaround you should be able to search for that service and delete it each time you're calling import_data with a spatial dataframe.
