Working from geometry to feature to map, can't display polygon feature
1917
01-26-2017 08:37 AM
JillKelly
New Contributor III
I've created a valid polygon geometry.
CTcorners = { 'rings' : [[[-72.0,42.0],[-72.1,42.0],[-72.1,42.1],[-72.0,42.1],[-72.0,42.0]]]} # clockwise
CTpolygeom = arcgis.geometry.Polygon(CTcorners)
I converted it to a feature.
CTpoly = arcgis.features.Feature(CTpolygeom)
That step seems to work properly, but when I try to add it to the map,
map2 = gis.map('Connecticut') # focus on CT
map2.basemap = 'topo'
map2.add_layer(CTpoly)
map2
it throws the error:
TypeError: argument of type 'Feature' is not iterable
on the add_layer line.  Do I need to make a layer of it for display maybe?
ps -- is 'rings' a reserved term in this context or arbitrary?  Thanks.
RohitSingh2
A Feature is not a layer and you wont be able to use map.add_layer() to draw the feature in the map widget. You can convert the feature to a featureset and use map.draw() to draw it:
   map.draw(FeatureSet([CTpoly]))
import_data() results in a FeatureCollection which is a layer that can be added to a map widget.
XuehanJing
New Contributor III
Hi Jill,
From the API documentation, I can tell the add_layer is used to add an existing item from your portal.
arcgis.widgets module — arcgis 1.0 documentation
Since your CTPloy is not an item, it may not work.
Maybe you can try draw(), arcgis.widgets module — arcgis 1.0 documentation
Thanks.
JillKelly
New Contributor III
"item" seems a little vague.  I can, for example, add_layer a set of points:
df1 = pandas.read_csv('CTpolygon.csv', header=0, names=['longitude', 'latitude'])
rows = np.random.choice(df1.index.values, 499)
df = df1.ix[rows]
CTpoints = gis.content.import_data(df)
map1 = gis.map('Connecticut') # focus on CT
map1.basemap = 'topo'
map1.add_layer(CTpoints)
map1
How is a polygon feature any different in terms of being an "item"?
RohitSingh2
JillKelly
New Contributor III
Thanks Rohit.  I had tried converting it to a Layer, but I overlooked FeatureSet.  It works!
