Why does exportToPDF cause "libpng error: Not a PNG file"?
1020
12-18-2020 10:24 AM
ArwenVaughan1
New Contributor II
I am using the exportToPDF function to export a layout to PDF and after each successful export the lines below are written to standard output. As far as I know there is no actual error or problem. Does anyone know how to avoid getting this output, which fills up your Std Out and/or log files?
Tags (3)
DanPatterson
MVP Esteemed Contributor
What version of arcgis pro or arcmap are you using? (it determines the version of arcpy)
... sort of retired...
ArwenVaughan1
New Contributor II
Hi Dan. I am using 2.6.2 currently. Any thoughts? I may try upgrading to 2.7 and see what happens.
DanPatterson
Before you leap!  Compare libpng versions using conda or your python list in the Project backstage.
(arcgispro-py3) C:\arc_pro\bin\Python\envs\arcgispro-py3>conda list libpng
# packages in environment at C:\arc_pro\bin\Python\envs\arcgispro-py3:
libpng 1.6.37 h2a8f88b_0
ArwenVaughan1
New Contributor II
OK, here are my results...same...it looks like
# packages in environment at C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3:
DanPatterson
Then don't go upgrading on a Friday... see if there was a bug in the first place and if so, see if it has been fixed
Release notes for ArcGIS Pro 2.7—ArcGIS Pro | Documentation
Then prepare for an upgrade on monday (there are a few "experiences" on upgrading to 2.7 you might want to look for over the weekend)
