Unable to update / delete user in ArcGIS Python API - HTTP 404 error
2093
15
02-03-2020 05:20 AM
PhillipGiraud
New Contributor II
I am trying to update a user's description in our ArcGIS Portal instance but the below code is giving me an HTTP 404 error:
from arcgis.gis import GIS
gis = GIS("my_portal_url", "my_user", "my_password")
user = gis.users.get(username="chris.buckmaster")
user.update(description="Chris's Bio")
The error I receive is as follows:
File "test.py", line 5, in <module>
File "C:\ProgramData\Anaconda3\lib\site-packages\arcgis\gis\__init__.py", line 5700, in update
files=files)
File "C:\ProgramData\Anaconda3\lib\site-packages\arcgis\_impl\connection.py", line 1107, in post
resp = opener.open(url, data=encoded_postdata.encode())
File "C:\ProgramData\Anaconda3\lib\urllib\request.py", line 531, in open
response = meth(req, response)
File "C:\ProgramData\Anaconda3\lib\urllib\request.py", line 641, in http_response
'http', request, response, code, msg, hdrs)
File "C:\ProgramData\Anaconda3\lib\urllib\request.py", line 569, in error
return self._call_chain(*args)
File "C:\ProgramData\Anaconda3\lib\urllib\request.py", line 503, in _call_chain
result = func(*args)
File "C:\ProgramData\Anaconda3\lib\urllib\request.py", line 649, in http_error_default
raise HTTPError(req.full_url, code, msg, hdrs, fp)
urllib.error.HTTPError: HTTP Error 404:
I can connect fine to the Portal and have been able to extract data out and produce reports etc so I am wondering why I might be receiving this error? I am using v1.6 of the ArcGIS Python API and Portal v10.6.
I am connecting as an administrator account so have full privileges.
Thanks
JakeSkinner
Esri Esteemed Contributor
Hi Phillip,
I was able to run this code using v1.7 of the ArcGIS for Python API and Portal 10.7.1.  I would try upgrading the API:
  1. Start > ArcGIS > right-click Python Command Prompt > Run As Administrator
  2. Execute the following:  conda upgrade -c esri --no-pin arcgis
PhillipGiraud
New Contributor II
Hi Jake
I have tried to upgrade to version 1.7 in the past but it just doesn't seem to be an option (have tried using the --no-pin command as well which I hadn't done before but it still doesn't give me the option to upgrade to 1.7).
I have checked the differences between 1.6 and 1.7 for this function and it is exactly the same so I am not sure whether an upgrade would help, but wouldn't have thought it is an issue with the API seeing as I can perform the other operations?
JakeSkinner
What version of ArcGIS Pro do you have installed (i.e. 2.4.3)?
PhillipGiraud
New Contributor II
Version 2.2.0 but I don't use the software.
ChrisBuckmaster2
New Contributor III
Any further ideas?
JakeSkinner
I would focus on upgrading to version 1.7 of the API.  If it's still an issue, then it could be related to the release of Portal for ArcGIS.
ChrisBuckmaster2
New Contributor III
Hi Jake
I get the below message when trying to upgrade, it seems to not recognise there being an option to upgrade to a newer release.
I'm not sure why it would be related to the release of ArcGIS Portal, as doesn't it get installed independent from any Portal environment?
JakeSkinner
Do you receive the same error when you run the above from C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3?
ChrisBuckmaster2
New Contributor III
Yes...
