Unable to find ItemInfo for item
1708
05-21-2019 05:11 AM
NikolajGrønholdt
I am experiencing a problem, when trying to use content.get(some item.id), in a script that indexes all the content of a Portal 10.7. When I run the script, It returns an error stating:
RuntimeError: Unable to find ItemInfo for item 'some id' (Error Code: 500)
It don't quite understand it, given that I have retrieved the id through content.search. So the item should be available on my portal.
Anybody who can point me in the direction for figuring this out?
MarisaClaggett
Do you have a snippet of the python you are using?  Can you manually look up that item id in your Portal?  What is the item type?
Best of luck,
Marisa
NikolajGrønholdt
Hi Marisa,
I experienced the error first in a quite complex loop, so I thought that it was a syntax problem. However, the error occurs even when using a simple gis.content.get("id"). The id that my script returns is 9b39c07049f64494ad8514d88aeadbc2, if it is of any interest.
I have since tried searching for it in the Portal as well, and it returns an item created by Esri (Screenshot below). When I try to access it by clicking view item details, my browser gets stuck loading the item details page.
ChelseaRozek
MVP Regular Contributor
I'm having the same issue. I seem to have a corrupted webmap item that doesn't load the item details page and I can't access through Python (says unable to find iteminfo for item 'ID#'). Looks like this in my content:
Were you able to resolve your issue before? I can't even delete it as it says it is either delete protected or has dependent items but I can't get in to check.
