Unable to connect to ArcGis Enterprise Portal via python using token
388
10-23-2019 06:22 AM
servicesigu
New Contributor III
Hello,
I want to connect to our ArcGis Entreprise portal in a python script using a valid token, but it fails ....
I execute this script from ArcGis Pro connected to our portal.
#My script "Script"
import arcgis.gis
import arcgis.gis.admin
import arcgis.gis.server
ent_gis = arcgis.gis.GIS(url=arcpy.GetActivePortalURL(),token=arcpy.GetSigninToken())
print(arcpy.GetActivePortalURL())
Messages
Start Time: mercredi 23 octobre 2019 15:01:01
Running script Script...
Failed script Script...
  File "C:\Users\freval-s\Documents\ArcGIS\Projects\MyProject5\portal_ent.py", line 6, in <module>
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 381, in __init__
    self._lazy_properties = PropertyMap(self._portal.get_properties(force=force_refresh))
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\portalpy.py", line 1088, in get_properties
    if resp:
UnboundLocalError: local variable 'resp' referenced before assignment
 Failed to execute (Script).
Failed at mercredi 23 octobre 2019 15:01:07 (Elapsed Time: 5,80 seconds)
MichaelWallace3
New Contributor III
This is how the getting started notebooks (Click on link Using Oauth 2.0) showed me how to access portal content.
Create a Python application on your portal
1. Sign In to Portal
2. Go to My Content
3. Click on Add Item and select application
4. Dialog appears and select Application
5. Name the application Python and give it a tag Python
6. Go to Settings under the application you just created and grab the client id
After you create the portal python application, Use the following code in your notebook
import arcgis
from arcgis.gis import GIS
gis = GIS("https://<portal address>/portal",client_id='###########') #client id is the id assigned to the python application
LuckyMishra
i am facing the same issue. service sigu please let me know if you solved it .
Thanks
