Trying to use jupyter notebooks and arcgis api to access sentinel data
210
6
08-18-2020 06:50 AM
BobClark
I am just getting started with python and the arcgis api and I’m trying to use jupyter notebook to analyse sentinel data for pre and post fire processing assignment. I found some help online but I keep getting stuck calling in the sentinel data and wonder if someone could please help me?
I would like to try filter by the date and intersection. Do I need to obtain a Token for the sentinel dataset?
from arcgis import GIS
gis = GIS()
sentinel_item = gis.content.search('Sentinel-2 Views', outside_org=True)[0]
sentinel_item
import arcgis
sentinel = sentinel_item.layers[0]
aoi = {'spatialreference': 'WGS 1984',
      'xmax': 15804453,
      'xmin': 17113072,
      'ymax': -3049737,
      'ymin': -3888071}
arcgis.env.analysis_extent = aoi
sentinel.extent = aoi
import pandas as pd
from datetime import datetime
startdate = pd.to_datetime(input("What is the fire start date "))
enddate = pd.to_datetime(input("What is the fire end date "))
selected = sentinel.filter_by(where="acquisitiondate BETWEEN timestamp 'startdate' AND timestamp 'enddate'",
                              geometry=arcgis.geometry.filters.intersects(aoi))
df = selected.query(out_fields='AcquisitionDate, Tile_ID, CloudCover', order_by_fields='AcquisitionDate').df
df['acquisitiondate'] = pd.to_datetime(df['acquisitiondate'], unit = 'ms')
Bob
Reply
GuneetMutreja
You would require an ArcGIS Online account to use Sentinel 2 Views. I would suggest you use : gis = GIS("https://www.arcgis.com", "arcgis_python", "P@ssword123") as your GIS object. The details of this account is mentioned in the guide here.
A screenshot is attached to show its working with the gis object mentioned.
Reply
BobClark
Thanks for your help Guneet!!
Reply
BobClark
I progressed the code further and was wondering if you could help with an arcgis method to mosaic all the sentinel tiles as my area is large. I'm also stuck on filtering by each day the capture was taken and saving throughout a fire event. I have screenshot where i am up to below.
Thank  you so much!!
Reply
GuneetMutreja
Hey Bob,
have a look at the notebook here. There are certain calculations that are performed here similar to what you are looking for. I believe this may help you out.
Reply
GuneetMutreja
Also, for creating mosaic the API has a mosaic function available. Have a look at this link.
Reply
BobClark
Thanks again Guneet. The links were very helpful!
Reply
