SSL Error access portal using arcgis python api Pro 2.6
1065
09-30-2020 05:28 PM
WesleyLiddell1
Trying to access portal using ArcGIS Python API
Has anyone been experiencing issues when trying to access portal through GIS when using Pro 2.6.x
Since installing this version the syntax below will fail when it previously worked.
from arcgis.gis import GIS
gis = GIS({PortalURL}, {USERNAMME}, {PASSWORD})
Error reported is
SSLError: Please set verify_cert=False due to encountered SSL error: HTTPSConnectionPool
If verify_cert=False is included it work fine.
All the servers have CA signed certificates and we see no SSL or certificate trust issues anywhere.
Anyone else experiencing this issue?
MehdiPira1
Hi Wesley Liddell‌,
I had this issue too. It looks like there is a bug in ArcGIS API for Python.
It's been logged as a bug for an SSL connection from the Pro 2.6+ python environment.
BUG-000118241: The Verify_cert parameter is not honored when connec..
