RuntimeError: The Field type is invalid or unsupported for the operation.
815
09-17-2019 01:05 AM
LinoSun
New Contributor III
When I use ArcGIS api for Python,there is an error appeared:RuntimeError: The Field type is invalid or unsupported for the operation..Whats wrong? Thanks.
EarlMedina
Hi Lino,
I noticed at least one of those fields contains special characters. If you don't include that column (or any other column with special characters) dose the code run fine? I wonder if the problem is the encoding in the text...
EarlMedina
Hi Lino,
Can you show us the previous lines that show what col is equal to?
-Earl
LinoSun
New Contributor III
col = list(sedf.columns)
EarlMedina
Hi Lino,
LinoSun
New Contributor III
I do not think the problem is the encoding in the text, because the problem is column "SHAPE", bu I do not know why it cause.
