Python API with Jupyter Notebook not displaying Maps
8543
17
08-05-2016 09:32 AM
JosiahCorona2
New Contributor II
I can get everything else returned except the maps. I know the page says its subject to change. Any ideas?
Seems this step might be the issue:
Enable map widget:
The ArcGIS Python API includes a map widget for embedding maps in the Jupyter notebook environment. To enable the map widget for all users, use the following command:
python -m arcgis.install
If you are on a Linux system and do not have permission to install the widget system-wide, you can install it in your local user profile by using the following command instead:
python -m arcgis.install -u
You can now start using the ArcGIS Python API in your Python IDE of choice, or the Jupyter Notebook environment.
AndrewHargreaves
Occasional Contributor II
I have this issue to but I DO get an error, namely:
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3>python -m arcgis.install
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe: Error while finding spec for 'arcgis.install' (<class 'ImportError'>: No module named 'arcgis')
jp
New Contributor II
I have the same environment as above and installed with: conda install  -c esri arcgis. as per the Install and Set Up | ArcGIS for Developers
But map isn't returned with my_gis.map()
jp
New Contributor II
I uninstalled and reinstalled arcgis package and the map is displayed now.
RosenoAdri
How to uninstall package?
by Anonymous User
Not applicable
After activating your environment in which you install the API, try below to remove `arcgis` package
conda remove arcgis
simoxu
by MVP Regular Contributor
Thanks, 'python -m arcgis.install' works.
by Anonymous User
Not applicable
Can you try installing arcgis again, If you still get that error try cleaning conda cache by 'conda clean -t' and then try to install arcgis.
PaulMallas
I found my issue to be I was launching 'jupyter lab' not 'jupyter notebook' as per the instructions. Force of habit.  Once I made that change, the maps displayed fine.
