I've noticed that after upgrading to ArcGIS Pro 2.2 that one of my scripts stopped working properly... I rolled back to Pro 2.1 and it worked again. Upgraded to 2.2 and it fails again. Anyone else seen this?
Leon
The script...
gis = GIS(agol_url, agol_user, agol_pass)
mySDfile = gis.content.get(itemid)
mySDfile.publish(overwrite="true")
The result....
KeyError Traceback (most recent call last) C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py in _check_publish_status(self, ret, folder) 6580 try: -> 6581 serviceitem_id = ret[0]['serviceItemId'] 6582 except KeyError as ke:KeyError: 'serviceItemId' During handling of the above exception, another exception occurred: KeyError Traceback (most recent call last) <ipython-input-3-eef2935b5006> in <module>() ----> 1 mySDfile.publish(overwrite="true") C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py in publish(self, publish_parameters, address_fields, output_type, overwrite, file_type, build_initial_cache) 6374 return Item(self._gis, ret[0]['serviceItemId']) 6375 else:-> 6376 serviceitem_id = self._check_publish_status(ret, folder) 6377 return Item(self._gis, serviceitem_id) 6378 C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py in _check_publish_status(self, ret, folder) 6581 serviceitem_id = ret[0]['serviceItemId'] 6582 except KeyError as ke: -> 6583 raise RuntimeError(ret[0]['error']['message']) 6584 6585 if 'jobId' in ret[0]: KeyError: 'error'
Just in case anyone does run into this, here is the result of my support case....
#BUG-000116104 Script used to publish an SD file from ArcGIS Pro to ArcGIS Online using the ArcGIS API for Python doesn't work successfully at ArcGIS Pro 2.2
I'm rolling back to version 2.1 for now.
Leon
Thanks for documenting this. I just ran into it while running the DevLab for Python - Import Data.
