Problem installing Jupyter Notebook and ArcGIS Python API after Mac OSX 10.12.5 update, Syntax Errors!
2473
10
07-14-2017 02:43 PM
LarrySpear
Anaconda Navigator installed OK. Jupyter Notebook Launch from Navigator and Terminal ("Jupyter-notebook") gets syntax errors. Also from Terminal ("conda install -c esri arcgis") gets syntax errors. Is the problem with latest OSX update 10.12.5?
by Anonymous User
Not applicable
Can you paste your error message? It would be easier to see what is going on.
As to support for OSX 10.12.5, my Mac runs this version and I do not have any issues.
LarrySpear
Hi Atma, Here are my error messages. Any help appreciated!
For Jupyter Notebook:
Larrys-Mac-mini-3:~ lspear$ jupyter notebook
File "/Users/lspear/anaconda/bin/jupyter-notebook", line 6, in
import pygments
File "/Applications/QGIS.app/Contents/Resources/python/pygments/__init__.py", line 46
except TypeError, err:
SyntaxError: invalid syntax
For arcgis:
Larrys-Mac-mini-3:~ lspear$ conda install -c esri arcgis
Fetching package metadata ...........
Solving package specifications: .
Package plan for installation in environment /Users/lspear/anaconda:
The following NEW packages will be INSTALLED:
arcgis: 1.2.0-py36_1 esri
Proceed (/n)? y
Uninstalling prior versions of arcgis widget
File "/Users/lspear/anaconda/bin/jupyter-nbextension", line 6, in
Non-degree Student URL: http://www.unm.edu/~lspear
University of New Mexico
Albuquerque, New Mexico 87131
LarrySpear
Hi Atma, My earlier reply was from email. Here is another with just specific errors.
For ArcGIS:
Could QGIS installed on this Mac be an issue?
by Anonymous User
Not applicable
Does the error here stem from pygments library installed with QGIS? One way to isolate this is to install and use the ArcGIS API in a new conda environment. I would recommend this as long as you do not have to use both QGIS and ArcGIS in the same python environment.
LarrySpear
Atma, This is strange as I also installed Anaconda and the ArcGIS Python API on my two old Linux-Ubuntu computers
the same day and both have QGIS and work OK. I rarely use my Mac and am also new to Anaconda so not sure yet
how to run in different conda environment ( I will look this up). One possibility is to just remove QGIS on the Mac as I
also have it on PCs and Linux computers. However, I only have one Mac. Any further suggestions would be helpful.
     --Thanks!
LarrySpear
Atma, Just created a new conda environment and tried install for arcgis python api and startng jupyter notebook.
Both failed with the same error message as before. If no further suggestions I will wait awhile before removing
QGIS to see what happens.
by Anonymous User
Not applicable
Can you run `conda list` from your newly created env and paste the result? That will help me figure out if you have just the arcgis library or any other libraries that might interfere. Also can you paste the full error message you get when start the notebook
LarrySpear
Atma, This are results for conda list and jupyter notebook from new environment (gisdev):
Larrys-Mac-mini-3:~ lspear$ source activate gisdev
(gisdev) Larrys-Mac-mini-3:~ lspear$ conda list
# packages in environment at /Users/lspear/anaconda/envs/gisdev:
(gisdev) Larrys-Mac-mini-3:~ lspear$ jupyter notebook
  File "/Users/lspear/anaconda/bin/jupyter-notebook", line 6, in <module>
    sys.exit(notebook.notebookapp.main())
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/jupyter_core/application.py", line 267, in launch_instance
    return super(JupyterApp, cls).launch_instance(argv=argv, **kwargs)
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/traitlets/config/application.py", line 657, in launch_instance
    app.initialize(argv)
  File "<decorator-gen-7>", line 2, in initialize
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/traitlets/config/application.py", line 87, in catch_config_error
    return method(app, *args, **kwargs)
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/notebook/notebookapp.py", line 1290, in initialize
    super(NotebookApp, self).initialize(argv)
  File "<decorator-gen-6>", line 2, in initialize
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/jupyter_core/application.py", line 243, in initialize
    self.migrate_config()
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/jupyter_core/application.py", line 162, in migrate_config
    from .migrate import get_ipython_dir, migrate
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/jupyter_core/migrate.py", line 35, in <module>
    from IPython.paths import get_ipython_dir
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/IPython/__init__.py", line 48, in <module>
    from .core.application import Application
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/IPython/core/application.py", line 25, in <module>
    from IPython.core import release, crashhandler
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/IPython/core/crashhandler.py", line 28, in <module>
    from IPython.core import ultratb
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/IPython/core/ultratb.py", line 119, in <module>
    from IPython.core import debugger
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/IPython/core/debugger.py", line 37, in <module>
    from IPython.utils import PyColorize, ulinecache
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/IPython/utils/PyColorize.py", line 57, in <module>
    from .colorable import Colorable
  File "/Users/lspear/anaconda/lib/python3.6/site-packages/IPython/utils/colorable.py", line 13, in <module>
    import pygments
by Anonymous User
Not applicable
I am afraid your conda env is not correct. For instance, when I run this, I get the following:
(arcgis_v12b) ~/Documents/code/geosaurus/geosaurus [create_replica_fix] $ conda list
# packages in environment at /Users/atma6951/anaconda/envs/arcgis_v12b:
appnope                   0.1.0                    py35_0
arcgis                    1.2.0                    py35_1    esri
bleach                    1.5.0                    py35_0
decorator                 4.0.11                   py35_0
entrypoints               0.2.3                    py35_0
html5lib                  0.999                    py35_0
ipykernel                 4.6.1                    py35_0
ipython                   6.1.0                    py35_0
ipython_genutils          0.2.0                    py35_0
ipywidgets                6.0.0                    py35_0
jedi                      0.10.2                   py35_2
jinja2                    2.9.6                    py35_0
jsonschema                2.6.0                    py35_0
jupyter_client            5.1.0                    py35_0
jupyter_core              4.3.0                    py35_0
markupsafe                0.23                     py35_2
mistune                   0.7.4                    py35_0
mkl                       2017.0.3                      0
nbconvert                 5.2.1                    py35_0
nbformat                  4.3.0                    py35_0
notebook                  5.0.0                    py35_0
numpy                     1.13.1                   py35_0
openssl                   1.0.2l                        0
pandas                    0.20.2              np113py35_0
pandocfilters             1.4.1                    py35_0
path.py                   10.3.1                   py35_0
pexpect                   4.2.1                    py35_0
pickleshare               0.7.4                    py35_0
pip                       9.0.1                    py35_1
prompt_toolkit            1.0.14                   py35_0
ptyprocess                0.5.1                    py35_0
pygments                  2.2.0                    py35_0
python                    3.5.3                         1
python-dateutil           2.6.0                    py35_0
pytz                      2017.2                   py35_0
pyzmq                     16.0.2                   py35_0
readline                  6.2                           2
setuptools                27.2.0                   py35_0
simplegeneric             0.8.1                    py35_1
six                       1.10.0                   py35_0
sqlite                    3.13.0                        0
terminado                 0.6                      py35_0
testpath                  0.3.1                    py35_0
tk                        8.5.18                        0
tornado                   4.5.1                    py35_0
traitlets                 4.3.2                    py35_0
wcwidth                   0.1.7                    py35_0
wheel                     0.29.0                   py35_0
widgetsnbextension        2.0.0                    py35_0
xz                        5.2.2                         1
zlib                      1.2.8                         3
I expect to see something like above if you installed the arcgis package in that environment. In your case the list is empty. At this point, I would recommend reinstalling anaconda and the ArcGIS package.
