'NoneType" Error when adding layer to WebMap using Python API
4789
8
07-16-2020 02:15 PM
Arne_Gelfert
Trying to add a layer (Portal item) to a webmap. The ESRI example for this I'm looking at is very simple:
streets_item = gis.content.search("LA Streets","Map Service")[0]
wm = WebMap()  # create an empty web map with a default basemap
wm.add_layer(streets_item)
Okay, so I have a web map that's not empty that I created like this:
print(type(target_item))
from arcgis.mapping import WebMap
web_map_obj = WebMap(target_item)
print(type(web_map_obj))‍‍‍‍‍‍
#>>> <class 'arcgis.gis.Item'>
#>>> <class 'arcgis.mapping._types.WebMap'>
The print() statements are only there to assure myself that I'm actually looking at items on and not itemId's or who knows what. So I have a legit Python web map based on on a web map item in Portal. As a check, I do...
web_map_obj.layers
# prints out all the layers (map image layers) that nelong to the Portal web map
 So now, I want to add another layer
newLayer = gis.content.search(query = "new layer"))[0]
# again just checking this is what I expect
print(type(newLayer))
web_map_obj.add_layer(newLayer)‍‍‍‍‍‍‍‍‍‍
Well, this bombs...
TypeError                                 Traceback (most recent call last)
<ipython-input-191-62f982ec1c55> in <module>
     13     # again just checking this is what I expect
     14     print(type(newLayer))
---> 15     web_map_obj.add_layer(newLayer)
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\mapping\_types.py in add_layer(self, layer, options)
    323
    324                 for lyr in layer.layers:  # recurse - works for all.
--> 325                     self.add_layer(lyr, options)
    326                 return True  # end add_layer execution after iterating through each layer.
    327             else:
    510                         fields_list = layer.properties.layerDefinition.fields
    511
--> 512             for f in fields_list:
    513                 if isinstance(f, dict) or isinstance(f, PropertyMap):
    514                     field_dict = {'fieldName': f['name'],
TypeError: 'NoneType' object is not iterable
What's wrong with what I'm doing? I realize there is also arcgis.gis.Layer. Do I first need to create a Layer from the item and then add that to the web map maybe?
Arne_Gelfert
So it looks like the following works:
newLayer_item = gis.content.search(query = "new layer"))[0]
# the following line is new and made this work
newLayer = arcgis.gis.Layer(newLayer_item)
# Now I can see the new layers with
web_map_obj.layers‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Anyone know if the above referenced original ESRI example will ever work and if I was doing something wrong?
JoshuaBixby
MVP Esteemed Contributor
Where are you executing your code from, Python interactive windows in ArcGIS Pro, Python command prompt, Jupyter notebook?
Arne_Gelfert
Jupyter Notebooks.
JoshuaBixby
Regarding newLayer_item, what exactly is it?  I get the Esri examples to work in Jupyter, after a minor change to search outside my org, so I am wondering about your layer.
Arne_Gelfert
NewLayer is a Portal item that references a Map Service on our federated GIS Server. Where this all started was when I looked into copying a web map item from one Portal environment (Test) to another (Prod) and then trying to replace some map services .
JoshuaBixby
Since the Esri examples work for me in Jupyter, and I can't test directly using your data, I don't have any other suggestions/ideas at this point.  Maybe a Pro version thing.  What version of Pro are you running?
Arne_Gelfert
This is Pro 2.5... I might try upgrading or at checking which version of arcgis modules my conda environment is using.
Arne_Gelfert
Turns out the syntax of the ESRI example works when adding an item (as layer) to web map using add_layer() works when it was created as empty new web map like this:
webmap = ‍Webmap()
But not when the web map was created off another item and already has some layers...
webmap = Webmap(item)
This may be explained somewhere in ESRI documentation. Good to know!
